Obd2 ECU Reflash?
Kevs02Accord
Obd2 ECU Reflash?
Post by Kevs02Accord »
Looking around at ways of tuning obd2 ecus. Just getting into the ECU reflash and was wondering what the advantages and disadvantages of this are, as opposed to and obd1 conversion? If you can reflash the ecu, how far can you take the tuning, etc...?
It depends on what vehicle you are asking about.
http://www.hondata.com/wizard/wiz_start.html
Kevs02Accord
Spunkster wrote:It depends on what vehicle you are asking about.
02 accord. I was aware of the obd1 conversion, right now I have an auto, so I am exploring other options, other than 5 spd conversion. Unless the hondata ecu with a separate obd1 tcu could control my transmission. Right now I am trying to explore an ecu flash, while keeping the stock pcm.[/code]
I'm sorry, but we don't offer anything for automatics.
Gen2ITR
Post by Gen2ITR »
Would there be any option for a 98 accord MT with an H23A swap?
We are running into immobilizer issues.
To use a Hondata system, you will need to use a compatible OBD1 ecu from the list at http://www.hondata.com/ecus.html . You can then use the Hondata s100 or s300 depending on what options you want ( http://www.hondata.com/sproducts.html ). I would recommend the s300.
