Hondata Boost Control solenoid - Problem
Import-JDM.com
Post by Import-JDM.com »
Hello Buddys,
I have one problem with tune my S300 for Boost Control.
I put 11 Psi for 1st, 2nd and 3rd gear and it makes:
1st -> 11 psi
2nd -> 15 psi
3rd -> 18 psi
I attached two Print Screens for Low and High Table, i use the Tial Spring Large Red 0.7 BAR - 10 Psi.
Why i put same pressure for 1st, 2nd and 3rd and it makes diferent pressures in each gear ?
Thank you for your time.
Regards
Pat
Screenshots do not help. You must post the calibration and a datalog showing the problem.
megomaniac
Post by megomaniac »
What kinda turbo/manifold/38mm or 44mm gate? maybe its just boost creep, due to manifold design or gate size, or maybe not 8)
H22A4
turbo
S300
Import-JDM.com
Spunkster wrote:Screenshots do not help. You must post the calibration and a datalog showing the problem.
Spunkster,
I cant make datalogs, i dont know why but when i use the datalogging after 10-20 seconds the datalogging break and i need restart the Smanager...
Regards
Pat
Import-JDM.com
megomaniac wrote:What kinda turbo/manifold/38mm or 44mm gate? maybe its just boost creep, due to manifold design or gate size, or maybe not 8)
I have the Full Race Turbo Kit Pro Street T3
Tial WG 44mm
Garrett Turbo T3/T67 H.O AR 0.82
Regards
Pat
Are you using non-resistor spark plugs?
locash
Post by locash »
With that turbo, you are getting boost creep. You are creating more exhaust gas energy in the higher gears due to the increased engine loading.. Run less duty cycle in the upper gears and see what happens.. You could also run a smaller turbo.. :)
Locash Racing, LLC
Hondata Sales and Tuning
Dynapack 4000 2wd Dyno
In-Shop CNC Machining and Product Manufacturing
Import-JDM.com
Hello Buddys,
I already see the problem is because the Gear Ratio, i select the right gearbox and final gear and now its okay.
Thanks for helps
Regards
Pat
Import-JDM.com
Spunkster wrote:Are you using non-resistor spark plugs?
Spunkster,
I continue with same problem in logs, with 11 psi i can see the log with more pressure the log break.
I have MSD Distribuitor and MSD Cables with Champion Plugs.
Regards
Pat
Try an OEM distributor and make sure you are using resistor type spark plugs.
Import-JDM.com
Spunkster,
I will try the plugs NGK-R5671A-9, is good ?
For abouth 600-700hp.
Regards
Pat
