KPro / KManager requests
Re: KPro / KManager requests
+1 on the S2000 coolant temp gauge.
Removed the pirate link. The S2000 coolant output is driven by the adapter, not the ECU. It's output cannot be changed.
Thanks for the explanation and sorry if the picture was inappropriate.
can we get CAN output support for native honda clusters such as the TSX cluster?
I'd be happy to mail you mine for developement
SilverRD1 wrote:can we get CAN output support for native honda clusters such as the TSX cluster?
^This. The Flashpro for the TSX is great for those who aren't getting into more engine work, boost, or wanting to elimate DBW (For off road use only of course).
Hello,
I am trying to get this wideband supported in order to run closed loop/open loop properly
https://www.bmotorsports.com/shop/produ ... ts_id/2334
NTK AFRM - Air Fuel Ratio Monitor Kit - Wideband O2 - PN 96604 - w/ NTK Sensor
Thank you very much.
Hi,
Would it be possible to add analogue outputs of the VSS & ECT?
This would be very useful for engine swaps if these two could be implemented, the VSS would need to be configurable for output wave form & speed to suit the wheel size. The ECT would need to simulate the variable resistance of normal temperature sender with a user configurable voltage slope.
Hi,
it would be great to be able to disable Fuel tank pressure sensor (P0452) without disabling OBD2. I'm running a european EP3 with PRC ECU and my car doesn't have a FTP sensor so I need to reset the fault code every now and then.
Would like to be able to tell the ECU what static fuel pressure i'm running and/or the ECU can adjust the values base on a fuel pressure sensor
Hello hondata or spunkster,
First of all I wish happy new near to all. I updated my kmanager on my laptop to 4.3.4. I tuned my customer’s car and my own car both cars rev limiter sound changed, now it cuts much slower it is more likly to oem honda ecu’s cut. Did you changed anyting on latest version?
The overall rev limiter or the launch limiter? What version did you upgrade from?
Overall rev limiter changed. I use 4.3.3 before this change.Hondata wrote: Mon Jan 01, 2018 5:24 pm The overall rev limiter or the launch limiter? What version did you upgrade from?
Is there any update about it ? Or can it be because of you add
“Added rev limiter sensor to datalogging.” feature new version of kmanager?
Yes, it was from the change for the datalogging of the rev limiter. Let us test this out and see how much difference there is.
Can I install back v.4.3.3 since they are using the same firmware I thought that it may work when downgrade the kmanager version.Hondata wrote: Fri Jan 26, 2018 12:23 pm Yes, it was from the change for the datalogging of the rev limiter. Let us test this out and see how much difference there is.
And also I couldn't find v4.3.3 on forum can you upload it here or write a link please.
