Re: SManager V1.5.3 beta
Posted: Thu Jul 07, 2011 2:50 pm
im having the same problem with this and currently using the newest beta version. unfortunately i found out the problem, you have to run as administrator to upload the calibrations for changes to take effect and then check the download for accuracy and it will actually works. otherwise by not running admin, i was unable to load my calibration correctly and different values will take effect. example would be: ( launch control would not take effect and car its lacking fuel) hope hondata fixes this problems! also currently using windows 7 and uninstalling smanager and re-installing it would not do anything.TheWickedOne1 wrote:So, since V1.5.2. I've been having an issue where downloading an existing map from a ECU, brings down a completely different calibration. I thought i was going crazy at first, but i then uploaded the correct tune in the car again setup for 1000cc injectors. I then switched power off, then powered car back on and downloaded the map again and gave me a completely different map again, i verified this by all my settings, Current injectors size changed, Fuel tables and Timing tables changed etc. I know Hondata prompts the user that it is recommended to always upload map as well check for accuracy. But what could've started all this ? I didn't have an issue on V1.4.8... very strange...I downloaded V1.5.3. I'll see if it continues with this version.
