Page 6 of 8
Re: 09 Si help with hybrid racing intake tune.
Posted: Mon Mar 21, 2022 1:18 pm
by akanep16
Is 4100 like a generic starting point or did you get that from looking at my logs for my car specifically
Posted: Mon Mar 21, 2022 11:47 pm
by EFICU
That one looks really good, no knock and all the fuel stuff looks really good. Go ahead and make another datalog when you have time, if it looks good we might be there.
4100 is based on your actual data yes. Essentially you want to make sure at a vtec rpm, the high cam should command as much or more fuel than the low cam. If you have it too early or too late, the crossover to vtec may not be ideal based on fuel demand. With yours, at 4100 is the middle of the road where it demands more fuel on the high cam which is what we want. As discussed, your fuel tables are pretty strong around that 4100 rpm, so we can raise it up or lower vtec by a few hundred if you wanted. I don't like picking generic vtec rpms, I like to tailor it to the vehicles specifically, which is why we tune all fuel tables to gather the data.
Posted: Thu Mar 24, 2022 3:47 am
by akanep16
Well I finally got to drive my car today I didn’t get to log but I did plug in at the end of my drive and saw 3 knocks with control up :/ but I’ll make a log on my drive home and send
Posted: Thu Mar 24, 2022 11:10 am
by EFICU
Okay sounds good. We'll keep working on it. If the knock is in the same area it might be false, but we'll cross that bridge if needed. We'll wait for the data.
Posted: Thu Mar 24, 2022 1:29 pm
by akanep16
Well here it is, idk why it started knocking now but not when we first loaded this calibration.
Posted: Thu Mar 24, 2022 4:56 pm
by EFICU
When was the last time you got gas?
Posted: Thu Mar 24, 2022 5:16 pm
by akanep16
This morning before driving lol
Posted: Thu Mar 24, 2022 5:29 pm
by EFICU
Gotcha. That can be the culprit in some scenarios. Especially when it comes put of nowhere. Are you filling up when you get gas, or just putting in a few gallons?
Posted: Thu Mar 24, 2022 5:35 pm
by akanep16
I’m filling up. Does it look like anything that needs to be adjusted or maybe just from gas?
Posted: Thu Mar 24, 2022 5:49 pm
by EFICU
How long does it take you to run through a tank of gas right now? For now, I would make another datalog tomorrow and let's see if there is a trend going on, then I can send you a new file. If you did get some poor gas, then it might be a good idea to pull some timing anyways for future occurrences. The knock control is going up and pulling timing as it's supposed to be so that is good. But maybe taking some out in the tables would be ideal for the future.
If you'd rather have a new file with less timing right now let me know, it's your car, so it's all up to you. Just saying we might see if there is a trend to where the knock is happening before we pull timing. But let me know, it's all up to you.
Posted: Fri Mar 25, 2022 7:35 am
by akanep16
It takes me about a week right now and I’m totally cool making more logs before adjusting I’d like to see if there’s a trend going. I’ll make a drive today and send it.
Posted: Fri Mar 25, 2022 11:05 am
by EFICU
Okay sounds good. We'll see if any trends appear and discuss how to tackle it.
Posted: Sat Mar 26, 2022 8:31 am
by akanep16
Here is two good logs from today. It appears to pop up when it hits vtec? Thats when i see it show on my app at least.
Posted: Sat Mar 26, 2022 9:24 am
by EFICU
Some of it is just into vtec, and now some on part throttle driving. Give this one a drive and let's see how it looks. If it stays knock free on this, we can run it until you fill up with gas again, then go back one revision. But give this one a drive when you can and we will go from there.
akanep16.SD.V2.Rev10 (Blended)(Vtec4100).fpcal
Posted: Sat Mar 26, 2022 4:10 pm
by akanep16
Shes back to normal pulling hard and feeling good! I made 2 logs on this one but cant find the other...ill try to get it pulled up but heres one with that pulling and no knocks so far! Knock control back down.
