fuel level gauge
R-12914
Re: fuel level gauge
Post by R-12914 »
Hondata wrote:Thanks for the testing. Because of the way different injectors are rated (voltage, pressure) the correct number for RC750s is probably around 800-850cc.
BTW now there are injectors with better spray patterns than the RC550, RC650 & RC750 injectors. On my car fuel economy improved and and spark plug fouling disappeared when I switched from RC750 to DW800.
Ok thank you, i will try this!
A user here has written as follows in conjunction with the TTS intake manifold of my rotrex supercharger kit!:
"You can't install other injectors than RCs on TTS intake without modifying it"
Can you post picture of the DW800 how to look like?
The TTS intake manifold looks like that:
And the Injectors clip into the intake manifold into the grooves (red mark in the picture above on the intake manifold):
The RC Injectors and adapter-clips looks like that:
I don't know if that fits?! :(
2008 Honda Civic TypeR FN2
ECU: 37820-RSP-E02
Flashpro: FP-SI-INT-21153
Software: 3.6.1.0
Firmware: 185
typer86
Post by typer86 »
Hi,
Test looks very good I will test the new version on Sunday evening my car is currently in the fair: tuning world bodensee 2015
Hondata can you post the dimensions of your dw 800cc injectors and their clips please? So we can check if it possible to change the injectors to the DWs without modify the manifold.
I will post my results too.
Thanks a lot for you're Support.
R-12914
Post by R-12914 »
What number must i put in, if i use your DW800 injectors?
Thanks!
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
typer86
Post by typer86 »
I think:
http://www.deatschwerks.com/products/fu ... 0-4-detail
800cc Fuel Injectors
Product SKU: 21U-01-0800-4
Hondata, please confirm.
R-12914
Post by R-12914 »
typer86 wrote:I think:
Yes! :)
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
We do not carry the DW injectors now, and you'll have to contact DW for the dimensions,
R-12914
Post by R-12914 »
I have already emailed DW and waiting for response!
Thank you!
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
typer86
Post by typer86 »
How long the Power-LED from the FlashPro will blinking in firmware update mode? After installing the Testversion of flash pro manager the flash pro needs a firmware update... How long it takes, approximately? Previously v2.1.3 was installed - Ok it is finished.
20 minutes after start it was finished. Strange
R-12914
Post by R-12914 »
It takes ca. 1 minute, Not longer!
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
typer86
Post by typer86 »
R-12914 wrote:It takes ca. 1 minute, Not longer!
I was in trouble with my USB stack - it cause the problem. It was fixed very easly after troubleshooting.
> I unplugged two more devices - after that it was finished very fast.
Thanks Matthias ;)
Here my results: with 800cc in both fields:
R-12914
Post by R-12914 »
How do you manage to ride the CTR S/C with 8.5 liters?
Do you find the gas-pedal? :D ;)
Greetings,
Matthias
ECU: 37820-RSP-E02
Software: 3.6.1.0
Firmware: 185
typer86
Post by typer86 »
My fuel tank was very empty at this morning. I could not trust the fuel gauge so I will refuel today and then I take a look of the ride bar if correct. :-D
And I am back in the action!
neoarks
Post by neoarks »
Congratulations hondata, this "beta" software works fine.
Thanks for the feedback.
typer86
Post by typer86 »
Yahhh Hondata, it works fine :)
At the moment I am testing with the 750 / 749cc value. Maybe the 770 is the correct value for the Rotrex S/C K20.
More details in next weeks...
Feedback:
The consumption with 800cc values are a little to high which is displayed on the board computer. In normal drive with low boost it displays 9/10 Liters. That is to high and does not match with the gas bill.
The fuel gauge is also fixed with this beta version :) nice work!
