FlashPro annoucement
FN2R-ER
Post by FN2R-ER »
So there is a chance that it will work , the ports should be the same as RSP E0# ecu's, I would like to know the reason for putting a different ecu in the South African FN2's than the rest of the world and what is the specific difference, because there was one guy in SA that had the reflashed hondata ecu and it only made the engine light come on and there was no performance increase. But as far as i understand the car still worked just for the exception of the engine light.
nunoctr
Post by nunoctr »
Hi hondata,
Thanks for the videos.
Do you know if the euro civic type R (FN2) have the same type of o2 sensor (wideband?) than the civic SI. Can we see the AFR with the flashpro in the euro type R?
Thanks again
Yes. I do not believe that the sensor is exactly the same, but it is of the semi-wideband type.
strider
Post by strider »
Is there any chance the Flash Pro could be compatible with a 2005 Acura TL 6 speed?
'98 Civic Hatch | B18C | 85mm 12:1 pistons | Ported head | Skunk2 Stage 2 cams
Sorry, no.
xjohnkdoex
Post by xjohnkdoex »
would the 07/08 model TSX's possibly fall under the acura group as per the announcement? thanks.
I'll cover all vehicles in one go to save a post for each one:
For the moment we're covering just the Civic Si & CTR. We do not know if we will expand model coverage to any other vehicles, and therefore can not give answers as to if we will cover a certain vehicle and when we might do so.
xjohnkdoex
haha, fair enough. thanks.
sass
Post by sass »
I can't find out idle control. If flash Pro can menage this option?
Thanks.
Cr-v RD8+K24A2turbo+Kpro V4 prb+NPR3/6Speed+ТС+ HFS4 v3.2.
DynoWheel = 472kW / 589 N.m
HRX One Mile Challenge = Max Speed 282km
Known as Sniper
Have needed to as yet. The idle learn is better than the previous generation ECUs and the idle is fairly stable.
soxfan143
Post by soxfan143 »
Hondata wrote:Have needed to as yet. The idle learn is better than the previous generation ECUs and the idle is fairly stable.
Won't using larger injectors without idle control mess up the STFTs and LTFTs? Or will changing the fuel in the cells at idle actually determine the trims at idle?
We compensate for larger injectors. The idle fuel trims are normal.
sass
Post by sass »
Then I will have an troubles with big injectors and hit camshaft as Skunk2 and Toda-a3?
They have idle 900 - 1000.
Thanks.
Known as Sniper
ImAuthenticFTW
Post by ImAuthenticFTW »
Doug are you still planning the 1 video a week or did the release of 3 videos at once take that away??
silverspoon1996
Post by silverspoon1996 »
Has there been a definite release date set yet?
