Page 4 of 4
Re: K24 base map maybe?
Posted: Fri Apr 22, 2022 5:34 pm
by EFICU
Yeah it looks really good. I made some very small part throttle fuel changes, and a few WOT changes. Overall it looks great, give this one a drive when you can and we'll see how it looks. It should only take another revision or two, if that. Feel free to make some multi gear pulls or something if you want, and try throwing in a fourth gear full from 3000-7000 to check for knock as well.
Chase_fa5.SD.Rev10 (Blended)(Vtec4000).fpcal
Posted: Sat Apr 23, 2022 4:14 am
by chase_fa5
Alright here's my data log for that one!
Posted: Sat Apr 23, 2022 11:27 am
by EFICU
Overall it looks really good. No knock even on the fourth gear pull which is good. I didn't see any clean third gear pulls, so go ahead and make another datalog with a clean third gear pull or two. Be sure to get the pedal to the floor on the third gear WOT pull so we know it's WOT.
Also, are you driving with traction control (VSA) on? If so, you might try driving with it off. It looks like when the tires are spinning it's kicking in and hurting your acceleration. It's totally up to you, just though I would mention. But go ahead and make another datalog with that calibration and we'll see how it looks.
Posted: Sat Apr 23, 2022 11:40 am
by chase_fa5
I have been driving with VSA on yeah, I'll be sure to leave it off for the next data log and I'll get that 3rd gear WOT pull
Posted: Sat Apr 23, 2022 11:41 am
by EFICU
Sounds good. We'll see how it looks.
Posted: Sat Apr 23, 2022 3:25 pm
by chase_fa5
Car definitely feels better with VSA off, got quite a few full gear pulls including the WOT 3rd gear, let me know what you think!
Posted: Sat Apr 23, 2022 6:50 pm
by EFICU
Yeah it looks a lot better with VSA off. If it was really kicking in those last couple datalogs which was causing the throttle to shut a lot. Overall it looks good, I made a couple adjustments. So take this one for a spin when you can, shoot for a datalog just like that last one with at least one clean third gear pull. This could be the one, but we'll see how it looks.
Chase_fa5.SD.Rev11 (Blended)(Vtec4000).fpcal
Posted: Sun Apr 24, 2022 2:11 pm
by chase_fa5
Car feels great! Here's what i got
Posted: Sun Apr 24, 2022 11:54 pm
by EFICU
It looks really solid Chase. Go ahead and make another datalog in the next couple days and post it up, we might be there. If it all looks good in the next one, I have one more trick for you to try out. But let's see how the next one looks and we'll go from there.
Posted: Thu Apr 28, 2022 11:26 am
by chase_fa5
Here's what i got
Posted: Thu Apr 28, 2022 8:06 pm
by EFICU
Looks good again Chase. I went ahead and put my last trick in this one for you. It's basically just an altered pedal map that changes the relationship between the throttle pedal and throttle body. Give this one a drive and see what you think. Then post up a datalog this weekend sometime. If it all looks good, then I think we're good to go.
Chase_fa5.SD.Rev11 (Blended)(Vtec4000)(Sport).fpcal
Posted: Fri Apr 29, 2022 1:10 pm
by chase_fa5
Here's the datalog i got for that, I definitely dig the feel of the throttle now
Posted: Fri Apr 29, 2022 10:27 pm
by EFICU
Looks solid. I made a couple adjustments in the WOT fuel based on some trends over the last few datalogs. This one should be it, make a datalog when you can and we'll see how it looks. I'll leave the sport pedal in based on the feedback.
Chase_fa5.SD.Rev12 (Blended)(Vtec4000)(Sport).fpcal
Posted: Sat Apr 30, 2022 4:24 pm
by chase_fa5
Here's what I got for that one, I did have VSA off, but it was raining so I was spinning in 2nd gear quite a bit, maybe 3rd too but I got some good pulls
Posted: Sun May 01, 2022 3:42 pm
by EFICU
Looks good. I made a small adjustment to the WOT fuel that's been a little stubborn, take this one for a spin when you can. Overall it looks good, just nitpicking, this one should be it.
Chase_fa5.SD.Rev13 (Blended)(Vtec4000)(Sport).fpcal
