07 civic si 3.5 CAI needs help
Woogie18
Re: 07 civic si 3.5 CAI needs help
Post by Woogie18 »
Mostly i need to look a reliable tuner around here for me to take advantage with the mods..anyway thank u for the info
EFICU
Post by EFICU »
If peak power is what you want and your only goal, then yes a dyno tuner would be ideal. If you're happy with perhaps 90% of peak power, but better drivability and fuel trims on the street, an e-tune will suit you better. You would want to discuss with a dyno tuner what their process is and do they tune each cam angle individually. Also ask if they do any part throttle tuning for street driving. If all they do is tune for WOT and don't care about part throttle fuel trims and knock, then you might keep searching. Some, not all dyno tuners, tune for WOT only and send you on your way. Leaving you with the possibility of excessive knock on the street in some cases and fuel trims that are less than ideal. So think about your goals, and be sure to check around before choosing a dyno tuner if you want to do that route.
Woogie18
Post by Woogie18 »
My goal is better drivability and fuel trims on the street..enjoyable to drive..since it is my daily car so i think etune is best for me..
