Password JDM Power Chamber Basemap??
protoge91
Re: Password JDM Power Chamber Basemap??
Post by protoge91 »
curtusz wrote:yeah the first one you got there is the best so far ... if you want to send that kal ... I can retard ignition where u got knock
what do you mean by the first one i got? is it called the cold air? i can send that...but i got less knocks on the very torquey one than the cold air one just so you know
2002 DSM ACURA RSX TYPE-S / K-PRO / PWJDM INTAKE / OBX V2 HEADER / HASPORT MOTOR MOUNTS / INGALLS ENGINE TORQUE DAMPER / K-TUNED BILLET SHIFTER / SCHROTH RACING HARNESS / ENERGY SUSPENSION
protoge91
Post by protoge91 »
curtusz wrote:very torquey and favorite so far log.kdl ... that 1
ok here is the kal
protoge91
Post by protoge91 »
curtusz wrote:hopfully last kal for this map
hey man this was that crazy powerful kal if i remember correctly
http://www.hondata.com/forum/download/file.php?id=6285
protoge91
Post by protoge91 »
protoge91 wrote:heres the very dangerous torquey kal log the one with too much knock..however this was the most powerful
and here is the log for the one in the post above...lets try to get the most out of this one
http://www.hondata.com/forum/download/file.php?id=6308
protoge91
Post by protoge91 »
ok heres the kal that i want us to work on ill log on both of them tommoro
protoge91
Post by protoge91 »
ok heres the log for the one above. it was taken day before yesterday...havent changed anything
http://www.hondata.com/forum/download/file.php?id=6307
protoge91
Post by protoge91 »
ok heres the log for that map driver plus son 160lbs temperature 66 degrees farenheit
protoge91
Post by protoge91 »
log
protoge91
Post by protoge91 »
!!!!! we did it!! no knock!!!!
protoge91
Post by protoge91 »
here it is. driver 140lbs temp 52 degrees farenheit
protoge91
Post by protoge91 »
here we go driver 140 temp 52 degrees F
protoge91
Post by protoge91 »
ok here it is
protoge91
Post by protoge91 »
here it is
protoge91
Post by protoge91 »
ok here we go a lil stronger did you alter vtec point? if so i think i can feel that
protoge91
Post by protoge91 »
a couple of knocks on this one..felt even better tho
