Page 4 of 5
Re: SManager V2.2.7 (beta)
Posted: Wed Aug 28, 2013 5:02 am
by 9queSt
perameters.....rev limit.....activation rpm and power reduction.
What was this set at in the older version that didnt allow user adjustment??
Posted: Mon Sep 02, 2013 4:51 pm
by 9queSt
Fuel protection does not work.
The afr was leaner then 11.4 in 3rd gear and the boost was well above 19psi.
options....settings....units....air fuel is selected.
Do I need to change it to lambda for fuel protection to work?
The log shows that Im in 4th gear when its really 3rd. I think this is because I have 12.5% in the speed sensor correction under....misc perameters. I changed the final drive to 3.7 and it reads great after re calc.
Posted: Tue Sep 03, 2013 4:22 pm
9queSt wrote:Fuel protection does not work.
What happens if you use the ELD input.
Posted: Tue Sep 03, 2013 6:18 pm
by 9queSt
Not sure but I know it used to work with version 2.2.4
Posted: Wed Sep 04, 2013 4:48 pm
Please try the ELD input. The D14 input is not a good input to use as it cannot read the full voltage range.
Posted: Tue Sep 10, 2013 5:30 pm
by 9queSt
Spunkster wrote:Please try the ELD input. The D14 input is not a good input to use as it cannot read the full voltage range.
do i need to cur resistors or anything in the ecu?
what settings do I need to change so the "protection settings" use the ELD?
Posted: Wed Sep 11, 2013 9:26 am
http://www.hondata.com/help/smanager/wi ... ghtsub=d10
You do not need to change protection settings they look at whatever is set for the wideband input.
Posted: Thu Sep 12, 2013 4:52 am
by 9queSt
I tried the ELD input. cloosed loop works but fuel protection does not.
Posted: Thu Sep 12, 2013 10:52 am
I have confirmed that there is a bug with the 2.2.7 and lean protection. We are working on it now.
Posted: Thu Sep 12, 2013 3:59 pm
by 9queSt
Spunkster wrote:I have confirmed that there is a bug with the 2.2.7 and lean protection. We are working on it now.
Thank you. Please let me know if you find a way to make it work.
Posted: Thu Sep 12, 2013 4:43 pm
It will be fixed in the next release in a week or two.
Posted: Sun Sep 22, 2013 12:07 pm
by 9queSt
Spunkster wrote:It will be fixed in the next release in a week or two.
I have FWD nationals this coming weekend. I have been getting lean afr. It would be nice if the lean cut worked. I need that new verison
Posted: Wed Sep 25, 2013 12:58 am
by allm0t0rGSR
Parameters Window>Nitrous/Aux Parameters>Fuel & Ignition
Fuel compensation....Percent instead of value
more easier to tune...
thanks
Posted: Mon Nov 04, 2013 11:48 pm
by VitViper
Could you please do me a favor and update the SManager software with the latest traction control software so I can connect to my DC2's traction control unit (which had the firmware upgraded by FlashPro Manager to include the launch compensation settings). Currently stuck using FPM to update the TC software settings and then switching to SManager to tune the car.
Posted: Wed Nov 06, 2013 4:13 am
by Johnny_9
Hope there is an update soon...
