Page 4 of 5
Re: FlashPro V1.5.6 (beta)
Posted: Tue Jun 18, 2013 11:15 am
by angelf1974
Please, add the possibility to change the gear ratios of the 07 TSX.
Posted: Tue Jun 18, 2013 1:06 pm
by VitViper
I derked.
Posted: Mon Jun 24, 2013 2:50 pm
by mucter
File naming for datalogs in the flashpro has been screwed up since the beginning of the 1.5.x branch. Names don't save in the flashpro when you change them, and then when you go to save a file out of the flashpro, the filename in the dialog is all wonky.
Re: FlashPro V1.5.6
Posted: Sat Jul 06, 2013 6:22 am
by Zoro2006
There is problems with Production release V1.5.6 and TSX calibrations. For example if I open any build in TSX calibration (as example TSX-07-8-DW600) save it to different folder and later open - error appears. Tried to do the same with older Beta V1.5.6 and there is no such errors.
Re: FlashPro V1.5.6
Posted: Sat Jul 06, 2013 7:50 am
by sass
I have the same problem
Re: FlashPro V1.5.6
Posted: Sun Jul 07, 2013 11:11 am
by BWelbourn
I just updated to FP Manager version 1.5.6 (production release: July 2, 2013) from the production release version 1.4.5. My datalogs from the first ECU flash under version 1.5.6 have K.Level recordings all at 98%. K.Level has never stayed at a constant level in my dataloging prior to version 1.5.6. Is there something wrong with the K.Level under FP Manager 1.5.6?
Thanks.
2012 Civic Si
FP-2012Si-110021
FP Manager Ver. 1.5.6
Windows 7 Home Premium
Re: FlashPro V1.5.6
Posted: Mon Jul 08, 2013 8:52 am
Zoro2006: This is to prevent manual transmission calibrations from being loaded into automatic transmission ECUs.
BWelbourn: You need to upload to the ECU again with 1.5.6
Re: FlashPro V1.5.6
Posted: Mon Jul 08, 2013 3:48 pm
by BWelbourn
Hondata wrote: BWelbourn: You need to upload to the ECU again with 1.5.6
Hondata, Thanks for the quick reply. I uploaded the calibration to the ECU for the second time under 1.5.6 (note: I unplugged FlashPro from the vehicle's OBDII port between the first and second ECU flash under 1.5.6) and still have K.Level "flatlined" at 98%.
Here is a copy of the calibration file and a datalog from the second ECU flash under 1.5.6.
Thanks.
2012 Civic Si
FP-2012Si-110021
test_v1.5.6.fpcal
test_v1.5.6.fpdl
Re: FlashPro V1.5.6
Posted: Mon Jul 08, 2013 11:26 pm
by sass
Hondata wrote:Zoro2006: This is to prevent manual transmission calibrations from being loaded into automatic transmission ECUs.
"automatic gear, manual transmission is not the problem, because when i load my calibration in PC the error appears. There were no such errors in previous 1.4.5 version"
Re: FlashPro V1.5.6
Posted: Tue Jul 09, 2013 11:36 am
This message is just ot inform you that you are using a shared calibration. There is nothing wrong with it. If you do not want the masseage to appear, plug in the FlashPro prior to loading the calibratoin in the FlashPRo manager.
Re: FlashPro V1.5.6
Posted: Fri Jul 12, 2013 9:41 am
by speedhacks
ยท [Civic Si] Added light control features for knock control and traction control
I am on an FG/FA 2007+ Civic SI calibration, nowhere is 'light control features' for knock enabled...
Re: FlashPro V1.5.6
Posted: Fri Jul 12, 2013 10:34 am
You must be using a race calibration whcih doe snot have these ooptions. You will have to use an AFM based calibration which can be tuned via MAP.
Re: FlashPro V1.5.6
Posted: Fri Jul 12, 2013 10:57 am
by speedhacks
Spunkster wrote:You must be using a race calibration whcih doe snot have these ooptions. You will have to use an AFM based calibration which can be tuned via MAP.
Ah that would explain it.
Will I need to have an airflow sensor plugged in for this? I do not have the MAF anymore as this is a turbocharged engine so I am not sure I can use an AFM based calibration.
I'm a little wet behind the ears with this.
Re: FlashPro V1.5.6
Posted: Fri Jul 12, 2013 11:05 am
by speedhacks
Will I need to have an airflow sensor plugged in for this? I do not have the AFM anymore as this is a turbocharged engine so I am not sure I can use an AFM based calibration.
I answered my own question. Heh - thank you!
Re: FlashPro V1.5.6
Posted: Tue Jul 16, 2013 12:31 pm
by soxfan143
On AFM Hybrid maps boost control duty will not datalog. It stays at 0 all the time. Any idea why?
