Page 3 of 4
Posted: Mon Jan 12, 2009 9:36 am
by cranny
if your spinning you dont get a very accurate datalog. im sure fonz will tell you the same thing. might have to wait till its clear again.
Posted: Mon Jan 12, 2009 11:53 am
by fonz600
yeah needs to be without spinning. That run was quite a bit leaner than your last but noticed your IAT temps were a lot colder.
Were do you live as your IAT temps are mega cold. Might need to tweak temp compensation to suit your climate.
Posted: Mon Jan 12, 2009 5:11 pm
by da_gawd
fonz600 wrote:yeah needs to be without spinning. That run was quite a bit leaner than your last but noticed your IAT temps were a lot colder.
I live in Canada and we've been having snowstorm after snowstorm. It might be a while before I can do another run. Its going to be -40 celcius tomorrow. Would temperature compensation work? Would I need a map for the winter and one for the summer? In the summer it can get as hot as 35 celcius.
Posted: Mon Jan 12, 2009 9:49 pm
by cranny
i live in same conditions and in canada. right now outside its -10 celcius , i dont know exactly what that is in farenheit but , its cold , lol.
Posted: Tue Jan 13, 2009 11:21 pm
by Zigg
(*Cx1.8)+32 = *F
14 - Sounds about right.
Looking forward to Thursday with a low of -19C!!!!
Posted: Wed Jan 14, 2009 2:36 am
by fonz600
Nah you should only need 1 map and temp compensation should compensate, pardon the pun, for the temp but keep an eye on your logs is always a good idea. Just run with the map before the last one as slightly richer on that one and will help with the colder weather till we get the temp compensation sorted.
Posted: Mon Jan 26, 2009 7:55 pm
by da_gawd
Hey Fonz, I was finally able to do a run. Its still cold but i did it anyway since the roads were fairly dry . I've posted it.
Thanks.
Posted: Tue Jan 27, 2009 1:06 pm
by fonz600
OK mate,
I'll take a look and get back to you.
Posted: Wed Jan 28, 2009 7:10 pm
by fonz600
What map was it you ran that datalog for?
Posted: Wed Jan 28, 2009 8:39 pm
by da_gawd
fonz600 wrote:What map was it you ran that datalog for?
i ran the map from Jan 1. You had modified on january 8 but I went back to this one because the car was running rich at WOT, probably due to the cold temperatures.
i've also attached the one from january 8.
Posted: Thu Jan 29, 2009 8:42 am
by fonz600
Thats fine mate. I was just confused as opened the last map I supplied and was surprised to see it was still rich.
Can you try a run with the 8/1 map as think most of the changes are already done on that map.
Posted: Fri Jan 30, 2009 4:11 am
by da_gawd
fonz600 wrote:Thats fine mate. I was just confused as opened the last map I supplied and was surprised to see it was still rich.
Okay, I'll do a run with the 8/1 map as soon as it stops snowing and the roads are dry.
Posted: Sun Feb 01, 2009 2:44 pm
by da_gawd
Here is a dyno run using the map from Jan 8.
Posted: Mon Feb 02, 2009 11:23 am
by fonz600
Starting to look better now mate. Try this.
Posted: Mon Feb 02, 2009 7:23 pm
by da_gawd
fonz600 wrote:Starting to look better now mate. Try this.
Here is a datalog using the new map.
