Page 3 of 3
Posted: Mon Sep 29, 2008 4:08 pm
You are getting a P0131 error not a P0132 error. There is no voltage reading from your O2 sensor in the ECU. I would suggest looking at the sensor and the wiring. You may want to follow the troubleshooting for that error code from the original S2000 Helms manual.
Posted: Sat Dec 13, 2008 6:57 pm
by special-ops-s2k
Garrett_si wrote:I finally installed and test my own S2000 K-pro on my 2004 s2k
the problem is the same
O2 sensor high voltage
and after disable 02 sensor, 02 sensor heater, and using secondary...
I have the 02 sensor low voltage
I understand that Hondata try to find a way to fix it
But I think I will convert mine to use the RSX wideband 02 sensor
how would one go about converting to the RSX wideband o2 sensor? and what benefits would this have over using the OEM S2000 sensor?
Posted: Sat Dec 13, 2008 6:58 pm
by Garrett_si
special-ops-s2k wrote:Garrett_si wrote:I finally installed and test my own S2000 K-pro on my 2004 s2k
RSX 02-04 sensor is wideband
S2k sensor is narrow
Posted: Sat Dec 13, 2008 11:05 pm
by special-ops-s2k
Garrett_si wrote:special-ops-s2k wrote:Garrett_si wrote:I finally installed and test my own S2000 K-pro on my 2004 s2k
oic... is it as simple as swapping them out?
Posted: Sun Dec 14, 2008 3:49 am
by Garrett_si
Posted: Sun Dec 14, 2008 10:10 am
by special-ops-s2k
fixed my above post so you could see what I was asking... I was wondering if it is easy as swapping out the RSX wideband sensor in place of the OEM s2k sensor... or are there other changes that need be made?
Posted: Sun Dec 14, 2008 10:22 am
by Garrett_si
Some mod into the ECU need to be done
Wiring/ 1 relay/ 02 sensor
Posted: Sun Dec 14, 2008 10:38 am
by special-ops-s2k
Garrett_si wrote:Some mod into the ECU need to be done
is there instructions somewhere that detail this process as I think that is what I will do.
Posted: Sun Dec 14, 2008 12:54 pm
by Garrett_si
no
use the rsx wiring schematic
Posted: Sat Apr 11, 2009 2:20 pm
by Garrett_si
Does Hondata fix the problem?
Posted: Mon Apr 13, 2009 3:15 pm
what problem?
Posted: Mon Apr 13, 2009 3:18 pm
by Garrett_si
closed loop control using the secondary 02 sensor
Posted: Mon Apr 13, 2009 3:40 pm
It has been fixed since the August release of beta software.
http://www.hondata.com/help/kmanager/whatsnewtopic.htm
Posted: Mon Apr 13, 2009 5:46 pm
by Garrett_si
so all the final release since should solve this issue?
