Sounds good. I finally had some downtime.
-Ed
need help with a tune
- CalibratEd
- Contact:
Re: need help with a tune
Instagram: calibrated.tuning
- CalibratEd
- Contact:
Finding as follows:
The part throttle table is running lean.
Vtec fuel table needs some fine tune adjustments.
Double check your TPS. In one of the logs it drops a bit.
-Ed
- CalibratEd
- Contact:
The Air fuels are off in these logs. Be mindful of the IAT and ECT fuel corrections. They are modifying your fueling. Also double check your engine coolant temperature sensor is working properly. The temperature did not change for a few logs which is kind of odd.
in log Datalog-231101-004 it looks like the sensors shut off and then come back on. Did the car shut off on you?
- Ed
ibarra1557
I think i turned the car off and then back onCalibratEd wrote: Thu Nov 02, 2023 6:25 pmThe Air fuels are off in these logs. Be mindful of the IAT and ECT fuel corrections. They are modifying your fueling. Also double check your engine coolant temperature sensor is working properly. The temperature did not change for a few logs which is kind of odd.
- Ed
ibarra1557
final settings lmk what yall think and big thanks to the homie for helping w the etune
ibarra1557
last logs
ibarra1557
- Ed
