stock basemap knocking baddd
koisky
Re: stock basemap knocking baddd
Post by koisky »
just got the logs and man this car drives so much better, i can tell a hugeee difference in power and responsiveness.
EFICU
Post by EFICU »
It looks killer man. Part throttle fuel is still great, no knock, and WOT only needed a couple 1% adjustments here and there. Take this one for a drive when you can, we might be there on this one. Glad you're happy with it. If the next one on looks good, I only have one more trick you might like. But we'll do that in the next revision.
Koisky.Hybrid.Rev11 (Blended)(Vtec4900).fpcal
koisky
Post by koisky »
Yea its feeling great, heres the new logs i had tons of fun with it this morning, And that trick you wanna show me is intriguing haha
EFICU
Post by EFICU »
That one looked good. We had a couple knock near redline so I pulled some timing out for that. Other than that, all the fueling looked. For this next one, I changed the pedal map which tightens up the pedal to throttle body relationship. See what you think, if you like the old pedal map we can throw it back in no problem. I wait until the end to put it in so you can get a feel for the car, then see if you like the sport pedal map. Other than that, everything else is the same in the tune.
Koisky.Hybrid.Rev12 (Blended)(Vtec4900)(Sport).fpcal
koisky
Post by koisky »
Got the logs, love the new pedal feel took a bit to get used too but its workin great for me now, rpms are crazily fluctuating whenever i have the ac on and i had the car turn off on me while on idle, gonna check my intake today since its been raining an insane amount and i have no water shield over it whatsoever
EFICU
Post by EFICU »
Yeah the datalog looks great. No knock which is really good news. Go ahead and make another datalog when you can and we will see if it stays knock free. If it does, we should be there. Also try to keep datalogging to see if you can capture some of the idle issues and perhaps a stall. That way we can look at the datalog to hopefully see something, but definitely check the car mechanically.
