Page 3 of 4
Re: Is my car running ok ?
Posted: Wed Nov 24, 2021 9:45 pm
by ShadowMoon
EFICU wrote: Wed Nov 24, 2021 6:04 pm That's a bummer it wasn't smoother. It might be that it likes running on the MAF sensor for part throttle. Either way, it looks a lot better and the knock is only happening in one area now. Let's see how this one looks, then we'll go from there. I think we're moving forward which is good, but we might take a slightly different approach depending on your feedback in this one.
Shadowmoon.SD.Rev02 (Blended)(Vtec4400).fpcal
This one feel better I suppose. What do you think about reving to 7500 RPM during this datalogging ? Was just wondering if it is safe to do so without blowing anything. I don't rev up that high as often as I do now with the datalogging so im just a little nervous heh.
Posted: Wed Nov 24, 2021 10:37 pm
by EFICU
Bummer you don't like how this ones feel. I went ahead and made this next one a hybrid version, so it will run on the MAF sensor for part throttle, and the MAP sensor for WOT. See what you think. This would be more like the old calibration, but hopefully still faster during WOT. Your WOT pulls looks like the car is pulling pretty good for no exhaust, but if you don't like how it drives I guess it doesn't matter then. The knock is getting better through, it's only happening in one area now, so that's good, before it was happening in a few areas. So we're definitely headed in the right direction, sort of.
If you're nervous about the 7500 rpm redline then just let me know where you're comfortable and I can set it just above that. If you like to shift at 7000, I can set it to 7200 so you only hit it on a missed shift or something. I can set it wherever, just let me know. For the third gear WOT pulls, run it to the RPM you're comfortable with from now on. The WOT fuel was pretty much dead on in that one, so no need to run it out higher than you're comfortable with.
Here is the next one.
Shadowmoon.Hybrid.Rev03 (Blended)(Vtec4400).fpcal
Posted: Fri Nov 26, 2021 5:17 pm
by ShadowMoon
EFICU wrote: Wed Nov 24, 2021 10:37 pm Bummer you don't like how this ones feel. I went ahead and made this next one a hybrid version, so it will run on the MAF sensor for part throttle, and the MAP sensor for WOT. See what you think. This would be more like the old calibration, but hopefully still faster during WOT. Your WOT pulls looks like the car is pulling pretty good for no exhaust, but if you don't like how it drives I guess it doesn't matter then. The knock is getting better through, it's only happening in one area now, so that's good, before it was happening in a few areas. So we're definitely headed in the right direction, sort of.
This one is pretty smooth altogether. In your opinion, Do you think the previous map is better or this hybrid one ? I want my car to run at it most efficiency and if you think the previous one is better, than we should go with what's best.
Posted: Fri Nov 26, 2021 5:44 pm
by EFICU
Nope, the data looks good even with the hybrid calibration. So if you're happy with it, then we will run with it. Some intakes just don't like running on the MAF sensor, this one seems to be working okay. That and the knock is more under control, we're down to only 5 and it happened in a couple small areas under conditions that make sense. So we're moving in the right direction, I just want to creep up on it so we can keep the performance in it.
Here is the next one. I made a couple WOT fuel changes, and some ignition. It all looks good, just trying to get it knock free now.
Shadowmoon.Hybrid.Rev04 (Blended)(Vtec4400).fpcal
Posted: Sat Nov 27, 2021 6:13 pm
by ShadowMoon
EFICU wrote: Fri Nov 26, 2021 5:44 pm Nope, the data looks good even with the hybrid calibration. So if you're happy with it, then we will run with it. Some intakes just don't like running on the MAF sensor, this one seems to be working okay. That and the knock is more under control, we're down to only 5 and it happened in a couple small areas under conditions that make sense. So we're moving in the right direction, I just want to creep up on it so we can keep the performance in it.
Ah I see, hopefully this one is good.
Posted: Sun Nov 28, 2021 12:02 am
by EFICU
Yeah it looks great man. We're there on all the fueling, the MAF scaling is dialed, and the WOT fueling looks dead on. We had a couple random knock at low speed, which were probably false or just odd things while you were in third gear at 10 mph, maybe rolling through a parking lot. Those wouldn't be anything to worry about. We did have a couple in normal operation where we have been working on, so I made some more changes there for this one. See how this one goes. We're right there, literally just working on this one area of knock, it looks killer otherwise.
Shadowmoon.Hybrid.Rev05 (Blended)(Vtec4400).fpcal
Posted: Sun Nov 28, 2021 5:00 pm
by ShadowMoon
EFICU wrote: Sun Nov 28, 2021 12:02 am Yeah it looks great man. We're there on all the fueling, the MAF scaling is dialed, and the WOT fueling looks dead on. We had a couple random knock at low speed, which were probably false or just odd things while you were in third gear at 10 mph, maybe rolling through a parking lot. Those wouldn't be anything to worry about. We did have a couple in normal operation where we have been working on, so I made some more changes there for this one. See how this one goes. We're right there, literally just working on this one area of knock, it looks killer otherwise.
Heres the next one
Posted: Mon Nov 29, 2021 12:50 am
by EFICU
Okay that one looked great, we're there I think. The only two knock we had were while you were decelerating in neutral or sixth gear down to something in the teens for mph and then clutching into to go into first gear. So they are not knock from normal ranges which is good. I made some ignition changes to stop that knock though, so we will see how it looks in this next one. We might be there though, if not, we're super close now.
Shadowmoon.Hybrid.Rev06 (Blended)(Vtec4400).fpcal
Posted: Mon Nov 29, 2021 3:30 pm
by ShadowMoon
EFICU wrote: Mon Nov 29, 2021 12:50 am Okay that one looked great, we're there I think. The only two knock we had were while you were decelerating in neutral or sixth gear down to something in the teens for mph and then clutching into to go into first gear. So they are not knock from normal ranges which is good. I made some ignition changes to stop that knock though, so we will see how it looks in this next one. We might be there though, if not, we're super close now.
Thats good to hear. Hopefully this one is good.
Posted: Mon Nov 29, 2021 6:04 pm
by EFICU
Looks good. Only one knock this time, and it was under the same exact condition. Slowing at 20mph and then clutched in and rev matched to put it into gear which registered a knock. I made some similar changes to this next one to try to stop it. Take this one for a drive whenever you can and we'll see how it looks. No rush, it looks great, just chasing that rev match knock basically.
Shadowmoon.Hybrid.Rev07 (Blended)(Vtec4400).fpcal
Posted: Mon Nov 29, 2021 8:13 pm
by ShadowMoon
EFICU wrote: Mon Nov 29, 2021 6:04 pm Looks good. Only one knock this time, and it was under the same exact condition. Slowing at 20mph and then clutched in and rev matched to put it into gear which registered a knock. I made some similar changes to this next one to try to stop it. Take this one for a drive whenever you can and we'll see how it looks. No rush, it looks great, just chasing that rev match knock basically.
I tried to recreate the knock during downshift on this one.
Posted: Mon Nov 29, 2021 8:51 pm
by EFICU
We might be there, no knock on this one and all the fueling looks great. Go ahead and keep datalogging over the next few days and let's see if it stays knock free over multiple days. If so, I think we're good to go. If it does get a random knock on a rev match it's no big deal, I just wanted to make sure we minimized it.
Posted: Mon Dec 27, 2021 5:07 pm
by ShadowMoon
EFICU wrote: Mon Nov 29, 2021 8:51 pm We might be there, no knock on this one and all the fueling looks great. Go ahead and keep datalogging over the next few days and let's see if it stays knock free over multiple days. If so, I think we're good to go. If it does get a random knock on a rev match it's no big deal, I just wanted to make sure we minimized it.
Been a while haven't got the time to do some datalog but here are some. Check out and few and see if this is good ty.
Posted: Mon Dec 27, 2021 5:45 pm
by ShadowMoon
ShadowMoon wrote: Mon Dec 27, 2021 5:07 pm
Posted: Mon Dec 27, 2021 5:46 pm
by ShadowMoon
two more
