Page 3 of 4
Re: Need help with basemap fbo fg2 while tuner is available
Posted: Mon Sep 20, 2021 2:15 pm
by joshuaanzures2002
i tried a couple things from videos i saw but still nothing doesnt even crank just everything turns off
Posted: Mon Sep 20, 2021 2:17 pm
by EFICU
Have you tried "returning to stock", then re-uploading the new tune?
Posted: Mon Sep 20, 2021 2:19 pm
yes then as soon as i turn the key everything just shuts off i have to disconnect and connect ground for it to turn on again
Posted: Mon Sep 20, 2021 2:31 pm
by EFICU
Interesting. I don't know that I have ever come across that issue. You might try leaving the battery completely disconnected for fifteen minutes or so and let it all reset, then reconnect and try again. The battery is fully charged right?
Posted: Mon Sep 20, 2021 2:32 pm
alright ill go ahead and try that hopefully it works so we can finish ill let you know how it goes and yes it is fully charged
Posted: Mon Sep 20, 2021 3:03 pm
It sounds like a battery issue and anytime there is load it dies. Check the battery cables as well.
Posted: Mon Sep 20, 2021 3:10 pm
Okay currently left it unplugged to see if it turns on next ill go check to autozone to get a booster and see if it is the battery
Posted: Mon Sep 20, 2021 3:40 pm
So it was the battery i got it running is it finished by any chance or do you still have to do more data logs?
Posted: Mon Sep 20, 2021 3:45 pm
by EFICU
It's 99% there. You can drive it to work with no issues, we can work on it whenever you have more time. And you can drive it however you want, you don't have to baby it or anything.
Posted: Mon Sep 20, 2021 3:48 pm
Well i called in they said it wasnt that busy so i have the time right mow rather get it over with now so i dont waste more of your time. If youd like send me next one to do the data log now that its running
And once again thank you very much!
Posted: Mon Sep 20, 2021 3:55 pm
by EFICU
Gotcha, I didn't see you posted another link to your drive. So it is Datalog4 then I am guessing is the newest datalog?
Posted: Mon Sep 20, 2021 3:58 pm
Yes lol since all that happened that was the last one i did after the one you sent me which was 5
Posted: Mon Sep 20, 2021 4:01 pm
by EFICU
Okay gotcha. So then no knock which is good, and overall the fueling was great. I made a couple small touches. It's literally 99.9% there, really just checking for no knock again in this one. If so, then it's pretty much good to go. To check for knock, make your normal third gear pull like you have been, then do one in fourth gear from 3000-7000 so we can make sure you don't get any knock in that range. If it stays knock free it's good to go, but we'll see.
And you can just run out and make like a ten minute datalog if you want, you don't have to do the 20-30 minutes if you don't have time. The third and fourth gear pulls are our main focus now.
joshuaanzures2002.SD.Rev06.fpcal
Posted: Mon Sep 20, 2021 4:07 pm
Alright sounds good man ill send data log as soon as its done!
Posted: Mon Sep 20, 2021 4:56 pm
