What basemap should I use ?
kj6564
Re: What basemap should I use ?
Post by kj6564 »
Hopefully this is good, did a pull by the beginning. Thank you again
EFICU
Post by EFICU »
Better, the knock is gone. Still chasing the WOT fuel a little bit. I finally took a bigger swing at it on this one. We'll see how it looks.
Same datalog and driving style.
KJ6564.SD.Rev07 (Vtec4300).fpcal
kj6564
Post by kj6564 »
Here is the datalog, im sorry for not uploading yesterday just things came up. Hope this is well. Hope you are doing well as well. Thank you !
EFICU
Post by EFICU »
The fueling is dead on now, had some knock pop up in the same area. I made a couple changes for that. Take this one for a spin and we'll see how it looks. I think we're finally there on fueling, just trying to get it knock free for you.
KJ6564.SD.Rev08.1 (Vtec4300).fpcal
kj6564
Post by kj6564 »
Here is the datalog for today. Hope this is well, i won't be able to upload tomorrow because there's rain, but its possible, i will try. Thank you!
EFICU
Post by EFICU »
Looks great! No knock and all the fueling looks solid. I am going to throw my sport pedal map in this next one to see if you like that or not. It should make the pedal relationship to the throttle body a littler better. Take it for a drive just like you have been and we'll see how it looks. I like to make sure they are knock free for a few datalogs before we call it good.
No problem on the next datalog, whenever you get it is fine. Everything looks great, we're 99.9% done.
KJ6564.SD.Rev08.2 (Vtec4300)(Sport Pedal).fpcal
kj6564
Post by kj6564 »
Sounds good , I also have a question. I have had a skunk2 intake for a while now just never installed it but I think it would be better to install that and the headers when I get them and then tune it with all that. But let’s say I put the intake b4 the headers , this tune wouldn’t work correct? Since the skunk2 intake is a 3.5 if I’m not mistaken.
EFICU
Post by EFICU »
Yes this tune we have been working on will run with the Skunk2 intake no problem. With all aftermarket intakes, I speed density tune them like you would for the big tube intake (ie Skunk, HR, K-Tuned), so it would start up and run fine. It will most likely be a little bit lean on the first datalog but not unsafe. We can clean it up within a revision or two if you want to put it on. But yeah, you can throw it on and it will run and drive just fine. If you were running a stock intake or a tune using the MAF, then yes it would run weird and not recommended. But since you're speed density tuned now, it would be close right away, but would need some minor cleaning up for my standards.
Do you know when your header is arriving, or are you waiting to order it? I hate to see you have the S2 intake just sitting around, let's throw it on and enjoy it while you wait for your header.
kj6564
Post by kj6564 »
Ohhh I see. I’m just waiting to order the header. I will try then to install the skunk2 intake as soon as I can. I’ve had it sitting for months now.
EFICU
Post by EFICU »
Sounds good. It's totally up to you. I have no patience when it comes to new parts and stuff for me, if I have it here I want to throw it on right away. But if you want to wait that's fine, just saying it's easy to clean up the tune if you want to throw it on.
kj6564
Post by kj6564 »
Yea i might throw it on once this weather clears up a bit. Here is the datalog for today, Car felt good. Hopefully this is good. Thank you!
EFICU
Post by EFICU »
Looks good again. Go ahead and make one more datalog this weekend, either day, and if it's good we can call it good for now. Then we'll get back on it when you put the intake on. But for now, let's do one more datalog any time this weekend and we'll see how it looks.
kj6564
Post by kj6564 »
Sounds good I will try to get one soon , there’s rain for today tm and Monday as well here on the east coast. So hopefully it clears up soon to get that datalog.
EFICU
Post by EFICU »
Good deal. We'll see how it looks!
kj6564
Post by kj6564 »
Here is the dataog finally. The weather finally cleared up. Hope this is good. Thanks!
