Page 3 of 4
Re: 06 civic si coupe need help getting it running right
Posted: Sun Jun 13, 2021 4:51 pm
by EFICU
Okay that one looked pretty good. I made some changes to the fueling, especially on the high cam. It also looks like the cam angle and everything is working properly. For some reason, the tuner decides to run 0* cam angle on part throttle with the turbo setup, which makes no sense.
Go ahead and make a drive with this one. Vtec will still be at 5500, go ahead and make a pull up from 2500-8000rpm in third gear. Once we get on a good track, the tune will need to be done completely to get it dialed. We will end up taking 10 revisions or so to get it right, are you okay with that? It will be difficult to do it any quicker unless you're okay with leaving it on the 0* cam only while you wait for your turbo.
Trippy OG Turbo Rev02.fpcal
Posted: Sun Jun 13, 2021 5:53 pm
by tripy4life
felt better
Posted: Sun Jun 13, 2021 6:07 pm
by EFICU
Take this one for a run. All we really need is a WOT pull in third gear from 2500-8000. Then we can move on to the next cam angle. Vtec will be at 4300 now.
Trippy OG Turbo Rev03.fpcal
Posted: Sun Jun 13, 2021 6:31 pm
by tripy4life
that one felt pretty good
Posted: Sun Jun 13, 2021 6:47 pm
by EFICU
Having a little trouble getting the fuel on the high cam to get right, everywhere else is great. I've added and added now with little response. Take this one for a third gear pull from 2500-8000. If the fuel doesn't get on track we'll have to check things mechanically.
How high of an elevation are you at?
Posted: Sun Jun 13, 2021 6:55 pm
by tripy4life
im in northeast Ohio not sure on elevation ill try that one in the morning
Posted: Sun Jun 13, 2021 7:00 pm
by EFICU
Okay sounds good. Well it's good enough to drive around if you need to, just avoid going WOT until we get it looked at. So you're not high up in the mountains or anything then, hmm. Because it's acting like it's in higher elevation. That intake you have may be a problem, I think you mentioned it was an eBay intake? We'll keep working on it. Talk to you tomorrow.
Posted: Sun Jun 13, 2021 7:04 pm
by tripy4life
thanks allot ill try switching it out to some thing diff after i try that one talk to you tomorrow
Posted: Mon Jun 14, 2021 9:21 pm
by tripy4life
ok that one felt a lot better but i didn't get good data logs due to raining and storms today but here are 2 data logs 1st one was stuck in traffic and 2nd one was raining hard and i was just having fun lol ill grab a good one tomorrow am
Posted: Mon Jun 14, 2021 11:46 pm
by EFICU
Looks like we're on track. You made a mini pull in this one, where were were lean before we are dead on now. So hopefully the datalog shows that tomorrow and we'll go from there. But it's promising for now.
Posted: Tue Jun 15, 2021 11:54 am
by tripy4life
ok couldnt get no good pulls a lot of cops out lol idle is a lil high now that it is runing better
Posted: Tue Jun 15, 2021 2:15 pm
by EFICU
Okay, we can go ahead and move to the next cam angle to keep the ball rolling. Here is the next one, 15* cam angle now with vtec at 4300 still.
Same type of driving and try to get a WOT pull in third gear as much as possible.
Trippy OG Turbo Rev05 (15Cam).fpcal
Posted: Tue Jun 15, 2021 4:45 pm
by EFICU
Forgot to lower the idle for you. In case you haven't taken the other one for a drive, here is that one with the idle at 850.
Trippy OG Turbo Rev05.1 (15Cam)(850Idle).fpcal
Posted: Tue Jun 15, 2021 6:44 pm
by tripy4life
yeah i went out and cruised with a few friends so here is a few datalogs i didnt use the one with lower idle ill wait till next one for that lol
Posted: Tue Jun 15, 2021 6:46 pm
by tripy4life
felt like a whole new car my old golf gti 1.8t had a hard time keeping up lol
