Page 3 of 4
Re: 2015 Civic Si Basemaps
Posted: Fri May 15, 2020 5:03 pm
by EFICU
elfdaddy23 wrote: Fri May 15, 2020 4:48 pm here is log 7 no KNOCK!! i ended up doing 2 3rd gear pulls and 2 4th everything felt great!
datalog 7.fpdl
Great news! I’ll be home in a few hours. I’ll take a look at it when I get home. It’s plenty good to drive on if you need to go some where. But I will look it over and get you the next revision when I get home. Glad it’s running good!
Posted: Fri May 15, 2020 5:12 pm
by elfdaddy23
sounds good man. I look forward to the next revision. I will be available all day tomorrow to run more logs as well.
Posted: Fri May 15, 2020 5:19 pm
by EFICU
Sounds good. It shouldn’t take too many more, just depends on how the fueling looks in this next one.
Posted: Fri May 15, 2020 11:21 pm
by EFICU
elfdaddy23 wrote: Fri May 15, 2020 4:11 pm no problems here. I like that you are OCD it means you value your work. I couldn't of asked for a better person to help me. I appreciate it a lot. I will get this tune uploaded and get you another log here in just a bit.
I appreciate that man, that's why I try to help you guys out on here. Thank you!
So that one looked great, as you said no knock, and the WOT fueling is almost dead on. I made a couple half percentage changes here and there, and a few part throttle fueling changes. It's inching it's way to to being really good, minor tweaks are helping a lot.
Take this one for a drive however you'd like. Just throw in at least on WOT pull in third like you have been. Fourth gear is up to you, pretty sure we're good there, but if you want to do those pulls to keep checking it that's fine with me.
elfdaddy23.SD.Rev06.fpcal
Posted: Sat May 16, 2020 8:45 am
by elfdaddy23
here is the 8th log i could only get 1 3rd and 1 4th gear WOT pull
datalog 8.fpdl
Posted: Sat May 16, 2020 9:21 am
by EFICU
Looks great! The only changes I made were to the fueling at idle in this next one really. It's pulling a little fuel at idle, so I took some out to get it closer. Other than that it is just about as good as it gets. If you want, go ahead and make a datalog this weekend sometime and post it up. Then I will ask you to make a datalog on Tuesday and Friday ish of next week. I like to see that the car is consistent over multiple days basically. But it looks great, hopefully you're happy with it. Once you get some mods on it it will open up some, but for stock it looks be pretty stout.
Posted: Tue May 19, 2020 11:08 am
by Chris0419
I have a 2015 civic si with a 3" ktuned catback exhaust and a skunk2 CAI. No problems with the car besides a battery charging light that came on after relocating it but theres nothing wrong with it charging. I would like a tune to get the most out of my car.
Posted: Tue May 19, 2020 11:18 am
by Chris0419
EFICU wrote: Sun May 10, 2020 3:57 pm
Chris0419 wrote: Fri May 08, 2020 9:43 am Could you also help me out with some tuning? I have a '15 civic si with a kyuned 3" cat back exhaust and a Skunk2 CAI.
Are you having any issues with the car, or just want it tuned? I don't want to hijack the OPs post, if you want to make your own post in the 9th gen forum on here we can discuss your car.
I have PM'd you.
Posted: Fri May 29, 2020 10:48 am
by elfdaddy23
hey threre, I know it's been a little longer than planed, I got busy and had to drive m truck for awhile. I have three up loads for you on the third one (log 12) there was 5 knock counts between counts 1 and 2 i don't know why. those were in 3rd gear pulls
datalog 12.fpdl
datalog 11.fpdl
datalog 10.fpdl
Posted: Fri May 29, 2020 1:54 pm
by EFICU
Overall it looks really good. A couple of the knock were at idle, which is a little weird, but your car did it once before in a previous revision. One knock was pretty legit, but the intake temps were getting pretty high. I already have a lot of timing being pulled hot for temps, so I pulled a little timing out of the ignition table itself. A couple other knock happened on your 3-4 shift. So I changed a few ignition settings to remove that, but it might take some more work to remove it. Try to make a few 3-4 shifts on your next datalog so we can work on it. I also made a couple fuel changes, nothing major.
elfdaddy23.SD.Rev08.fpcal
Posted: Sat May 30, 2020 4:43 pm
by elfdaddy23
just got the revision. I will run it tomorrow and upload a log thanks again.
Posted: Sun May 31, 2020 7:29 am
by elfdaddy23
here is the latest log. there was only one knock count this time.
datalog 14.fpdl
Posted: Sun May 31, 2020 8:52 am
by EFICU
Interesting spot where it knocked, but nothing crazy. Super light throttle and you got into a really low load area so I took some ignition out there. Also made a couple fuel adjustments. We should probably be there on this one, we'll see how it looks.
elfdaddy23.SD.Rev09.fpcal
Posted: Tue Jun 02, 2020 6:04 am
by elfdaddy23
awesome gonna run it this morning log it and upload it. thanks again!
Posted: Tue Jun 02, 2020 8:38 am
by elfdaddy23
here is the latest log no knock this time to the is good!!
datalog 15.fpdl
