2012 Honda civic si knocks
EFICU
Re: 2012 Honda civic si knocks
Post by EFICU »
Yeah it’s scary seeing stuff like that. Every one of these car generations have their own quirks, that happens to be one on the 9th’s.
AGP7827
Post by AGP7827 »
ok did a lil drive gas almost gone
EFICU
Post by EFICU »
Here is the next one. This one will be the last one we do where we lock on cam angles it looks like. After this one we blend everything out. All we really need on this one is a WOT pull in third gear if you want to run out and make one. Up to you. Vtec will be at 3800 on this one.
AGP7827.SD.Rev05 (40cam).fpcal
AGP7827
Post by AGP7827 »
For this one try n do 3rd gear pulls from 2500 to red more often right
AGP7827
Post by AGP7827 »
For 15 mins or the full 20
EFICU
Post by EFICU »
No. Just one WOT pull in third gear is all we need. You can take it for a five minute drive if you want. I just need to see a third gear pull is all.
AGP7827
Post by AGP7827 »
3 pulls only seen one knock
EFICU
Post by EFICU »
Okay so here is the first revision towards finalizing everything. Everything is blended out so we'll see how it runs now. Which SRI do you have on the car? The intake temps are consistently high in the datalogs. With the temps in the datalogs the ECU will be pulling fuel and spark to keep the engine happy. So you will lose a little bit of performance there. If you switch to something like the Acuity intake down the road it would help the intake temps a bit. Just something to keep in mind.
Anyways, take this one for a spin when you want and see what you think. It'll take another revision or two to dial everything in, but this will be a good look at how it will perform. Vtec looks the be happiest at 4500, see what you think about the engagement point being there.
AGP7827.SD.Rev06 (Blended).fpcal
AGP7827
Post by AGP7827 »
ok iknow the way i have it sucks but i have a dc spot sri notice i lose mid range power was thinking about going bck stock but might keep it sri or should i go bck stock or get like a heat shield to help keep away heat but will it effect the tune if i go back stock
AGP7827
Post by AGP7827 »
or should i just go CAI
EFICU
Post by EFICU »
Yeah you’ll be losing some power all over with the intake temps where they are. Especially when the really hot weather comes. Stock intake is just as bad. Once the stock intake box gets hot the heat doesn’t go away. It heat soaks really easy.
I would recommend something like the Acuity intake for the 9th gens. Large tube design and gets everything away from the heat.
Any intake change will need some tuning adjustments. But if you do get the Acuity or something just let me know, we can touch it up. We’ll get it cleaned up as good as we can for this intake though.
AGP7827
Post by AGP7827 »
ok will look into the Cai
so after this tune whats next or im all set? because i remember u said it may take 12 or more revise
AGP7827
Post by AGP7827 »
because my next step is a skunk with high cat may or may not put back on res
EFICU
Post by EFICU »
Some take less. Your car is really consistent which is nice. It will still take another couple revisions to get it all dialed in. On your next datalogs, go back to the twenty minute datalogs like before. Throw in your normal third gear pulls and try to make a fourth gear pull if possible. Fourth gear can get pretty high speed, so your fourth gear pull run it up to 6500 or so. No need to get a crazy speeding ticket.
Yeah once you get an exhaust and exhaust just let me know. We can dial it in for all that stuff. Opening up the exhaust will open it up a lot.
AGP7827
Post by AGP7827 »
ok will do it tomorrow can rn hard to see lol best in the day time but i am going to upload the tune n run it tomorrow then send it to u
