Page 3 of 3
Re: air con problem
Posted: Mon May 18, 2020 11:38 am
It sounds like there is no problem then.
Re: air con problem
Posted: Sun May 24, 2020 7:01 am
by haRRibo
But where is a problem? In hondata settings?
What to do? I can“t run a car on ECU with disconected Hondat.
Re: air con problem
Posted: Tue May 26, 2020 2:55 pm
You need to try this ECU on a different known working vehicle.
Re: air con problem
Posted: Sat Jun 20, 2020 11:39 am
by haRRibo
OK I will do soon
Re: air con problem
Posted: Sun Jun 26, 2022 8:55 pm
by topsimportgarage
haRRibo wrote: Sat Jun 20, 2020 11:39 am
OK I will do soon
Any updates on this? Im running into the same problems on my setup. Ive seen a few other post about AC clutch not working with the S300 and nothing concrete it was resolved by either S300 setting or externally.
Re: air con problem
Posted: Thu Jun 15, 2023 3:46 pm
by euroslo24
running into the same issue
b5 input works correct
a15 output does not ground
if i play with nitrous output with a15 and invert it i can get it to ground the clutch but this is not a permanent solution
Re: air con problem
Posted: Thu Jun 15, 2023 3:49 pm
Most likely it is an issue with the ECU itself as they are over 25 years old and may be damaged.
