Page 3 of 3
Re: Innovate LC1 wideband setup
Posted: Fri Nov 09, 2018 5:11 pm
by AREA876
I will try and then report
Posted: Fri Nov 09, 2018 6:15 pm
by AREA876
Tried connecting LC1 12v source directly to the battery but no change
K20A3 Base Map-181109-002.kdl
Posted: Mon Nov 12, 2018 11:36 am
by AREA876
Any update on this problem
Posted: Wed Nov 14, 2018 6:48 am
by AREA876
Any followup information on this issue.
Posted: Wed Nov 14, 2018 10:12 am
not yet
Posted: Wed Nov 21, 2018 4:38 am
by AREA876
Any followup info
Posted: Thu Nov 29, 2018 4:36 am
by AREA876
Anything yet?
Posted: Thu Nov 29, 2018 10:17 am
We have not been able to reproduce anything here.
Posted: Thu Nov 29, 2018 4:48 pm
by AREA876
Do you have any suggestion as to what I can do to resolve my issue of A/F and analog not matching
Posted: Thu Nov 29, 2018 5:49 pm
You may want to use a different wideband. We recommend using the PSX Devices widebands.
Posted: Sat Dec 08, 2018 4:58 pm
by AREA876
I'm still thinking there is something wrong with the LC1 conversion, using the LC1 conversion this is the result
Notice AN3 is way off from the LC1 reading and the AF is still not matching with AN3
Posted: Sat Dec 08, 2018 5:02 pm
by AREA876
Now when I use a custom conversion this well give a perfect match between AN3 and the LC1 reading but the AF still doesn't match
So my belief is the LC1 conversion is not correct.
I'm trying to figure out if it's my ECU or Kpro that has a problem that's why the AF and the AN3 are NOT matching
Posted: Sat Dec 21, 2019 1:40 pm
by AREA876
Problem solved, the issue was my input wasn't set correctly. My wideband was connected to analog 3 while my wideband input was set to 0 which was my coolant pressure sensor. It's now set to analog 3 and everything is working fine
