Hondata Mobile APK 1.5 (Android) for Dash
RL3
Re: Hondata Mobile APK 1.5 (Android) for Dash
Post by RL3 »
Good Evening Hondata / all,
I'm having trouble with connecting the Honda Hack to my head unit. I've followed all steps to the letter, disabled antivirus and restarted the laptop, but when Honda Hack runs, it says it is unable to connect to device. I've followed all steps again to make sure USB debugging is on and the role is set to device. Any thoughts?
We've found that with some laptops it is very slow or doesn't work at all, so try another laptop if you can.
Also I have found that after you start up HondaHack unplugging/replugging the USB cable helps.
If all else fails there is always the no laptop / online solution for $10 from China.
Digenex
Post by Digenex »
Just installed V1.5 on my android HU and runs great!! very good update for us European / metric system users :-D
andyswmr714
Post by andyswmr714 »
This installation procedure should work for the Accord as well?
2018 accord
No, this will not work on the Accord.
high718
Post by high718 »
Any updates coming for the App?
TSACR
Post by TSACR »
I've been struggling to get Hondata Mobile APK 1.5 to pair over bluetooth. Perhaps it's b/c I have a late model 2018 with newer bluetooth? I'm able to pair via my iPhone but I can't pair from my Head Unit (HU) to the Flashpro.
Facts: Late 2018 Type R, rooted HU, Hondata APK 1.5, Flashpro 3.2.7.0, 2018+ bluetooth option checked off in FlashPro Manager, HU is showing the FlashPro bluetooth device as being paired. The bluetooth is showing up as a phone and not media within the HU - not sure if it makes a difference or not.
Flashpro Version: 3.2.7.0
Model Number: MY16ADA
Android Version: 4.2.2
Baseband Version: Unknown
Kernel Version: 3.1.10+
jenkins@NDYWY3861584 #1
Build Number: 1.F1A2.34
Any input would be appreciated from the community.
I do not think you need to select the 2018+ Alternative Paring method for the Type R Civic.
TSACR
Post by TSACR »
I do need the 2018+ Alternative Paring method for the Type R Civic in order for the HU's bluetooth to detect the device and pair. I tried unchecking and the previously paired bluetooth device on my HU deleted automatically.
Resolution:
I cleared all bluetooth devices from my HU, checked 2018+ Alternative Pairing, reboot FlashPro, paired the FlashPro device to the HU, disconnect (NOT REMOVED) the bluetooth device from the HU, launch Hondata Mobile and click on lighting bolt, and it finally connected! Not sure if this is an end user error or an updated bluetooth manager on my HU that allows a single bluetooth connection so that no other devices can connect to it but it certainly is painstaking to disconnect the bluetooth device from my HU each time to use the app.
FK8typer
Post by FK8typer »
Hondata wrote: Tue Aug 28, 2018 5:07 pm Here the current test version with logging.
Hondata-Dash-App-v1_5_1.apk
This version works great on my 17 Fk8 type R.. auto connected every time. I like how you can change the gauges.
FK8_K20c1
Post by FK8_K20c1 »
I works for me too 17 Type R. But I have noticed that some readings are only displayed on the 3 digital gauges only. Like Voltage. I would like to get the voltage readings on the 8 digital readings at the bottom.
aryeff112349
Post by aryeff112349 »
Hi sir
sorry to asking help from this site
But sir
kindly please assist me.
my car honda civic fd2 type r
i using aftermarket android head unit.
right now i using hondata apk version 1.3 from playstore. It function like normal. i can connect to hondata flashpro and i can acess to info in hondata. it function like charm.
But my problem i having untill now i cannot acess to setting function.
my display not show setting button. same like smartphone on landscape mode.
situation on smartphone we can access setting if we put on portraits mode. but my android head unit cannot put to portraits mode
i try to install hondata APK 1.5 from this site but it keep exit itself when i open. Same situation when i install this 1.5 version to my android smartphone.
Kindly please help me. i enjoy using this version hondata. i also have paid version but it dont have knock count and it show to many gauge on screen. i just want to change setting hondata on my head unit.
aryeff112349
sory not tell your team what actualy i need sir. what i means in my post please add setting button on landscape orientation for version 1.3. Right now setting only avaible on portraits orientation
Use the 1.5 version you can download from FlashPro manager.
aryeff112349
thank you sir for helping me.
love this version to my head unit
thanks once again sir.
