FlashProManager V2.8.7
zaramatt
Re: FlashProManager V2.8.7
Post by zaramatt »
So using a window switch to a relay controlling a 5v source instead of the ethanol sensor. Would this work for a dry nitrous system? Could you retard timing and add fuel with the 5 volt signal?
It might work, but we would not recommend it since the ethanol input is designed for flex fuel.
R-12914
Post by R-12914 »
typer86 wrote: Mon Jan 08, 2018 7:15 am Issue for: Civic SI/FN2 (Type-R) 2006:
If gear is in neutral and the clutch is not pressed, the engine is revving high until limiter! (overrevving)
Is this normal? Before the engine stop revving until 4500 rpm.
Please fix this.
Thx
Yes,
this function is unfortunately no longer available, since the change to set the "launch limiter" and "full throttle shift", etc. in FP-manager.
Actually, Honda has installed this function for engine protection in standstill (protection against overheating)!
2008 Honda Civic TypeR FN2
ECU: 37820-RSP-E02
Flashpro: FP-SI-INT-21153
Software: 3.6.1.0
Firmware: 185
