B16a fully Built, OBX turbo, RC1000cc, Ran good with chipped ECU, Installed s300 I cant get to run!!!!!!
Re: B16a fully Built, OBX turbo, RC1000cc, Ran good with chipped ECU, Installed s300 I cant get to run!!!!!!
Make sure the s300 is properly seated on all the pins inside the ECU.
AREA876
Post by AREA876 »
You should be able to datalog once ignition is on even if the engine is not running.
cbye
Post by cbye »
ok=) so im not going crazy, lol........ I have removed the sister board double checked my solders, there was one pin on the 48 connector that had slightly lifted from previous owner installing chips, but thru my years repairing circuit boards for an ag manufacturer I see nothing wrong with my soldering work and feel that its repaired sufficiently. Going to reinstall the board and try again.
Just to eliminate my confusion, being i havent seen the s300 work normally, even thou it says it is!!!!!!!!!!!!!!!
So when i turn ignition on with the usb cable connected, click the lightning bolt DATALOG shows up on bottom toolbar; at that point i should be seeing live sensor input values on the Sensor window??
AREA876
Post by AREA876 »
cbye wrote:So when i turn ignition on with the usb cable connected, click the lightning bolt DATALOG shows up on bottom toolbar; at that point i should be seeing live sensor input values on the Sensor window??
Yes that's correct
cbye
Post by cbye »
Ok so got all put back together, The s300 says everything is working but when click data log the tps sensor goes from 0 to -13. And doesn't change when opening throttle?? still read button produces min -5 max 60.
the map sensor reads -29.5 and never changes. Bat Voltage always reads 0
Does this sound like hardware or software??? I was gunna try just reinstalling smanager
an next was gunna try removing those other two resistors??
after that all I think can do is bust out the multimeter and test circuitry from all the pinouts?
What's the odds that the s300 board is faulty??
cbye
Post by cbye »
trying to rule some things out narrow down the issue any tests you know of to rule out hardware faults without testing each circuit with meter??
AREA876
Post by AREA876 »
cbye wrote:Does this sound like hardware or software??? I was gunna try just reinstalling smanager
To me it seems like the problem is your ECU, I would recommend trying the s300 in another ECU
cbye
Post by cbye »
Ok so got another ecu..... but its the rare pr3 obd1 ecu.... I did lil research and says its just like p30, will it work with s300?? I cant find anything on it in hondata ecu identification Part#37820-PR3-J01
cbye
Post by cbye »
Its virgin and boards look like new inside, Looks a lot better quality than the p28....... but different in some ways, i see it still has the components that need be modified and the three spots are empty where the new stuff goes=) please tell me it works, lol
AREA876
Post by AREA876 »
You should post a photo of the PR3 ECU, maybe then you will get a better answer.
The PR3 is a JDM ECU and the P28 is US so the s300 are different
That ECU should work, there may be some additional errors you will have to disable since that ECU may have some components missing.
cbye
Post by cbye »
S300 now working great=) it started even with stock b16a map with few changes. Half the battle is over!!!!!!! Sooooooo pumped.... now where to go from here??
cbye
Post by cbye »
Well Car is running and driving, now drive and tune drive and tune, dyno scheduled for end of august, any tips or advise on adjusting fuel tables?? It seems im constantly changing things and feel im just making things worse?? trying to keep around 14.7 More fuel, less fuel!!!!!!!! over and over??
AREA876
Post by AREA876 »
Are you in open loop when tuning
cbye
Post by cbye »
im in open loop, there is the estimated fuel change tab in tables window. I been using that to determine adjustments, but after adjusting the table can you reset the estimated tab. so isn't affected by previous calibration values??
