KManager V1.4.5.7 Beta
roland
Post by roland »
Thanks for the update, I'll test it out tomorrow morning :)
kidinatype_S wrote:In the main Table, drop down, went to WOT comp(cat protection) low, and high speed. I am unable to edit these tables. Like if I select all, and hit control D nothing changes? I want to know since I am not using a cat. Also the Same goes for the normal WOT comp tables, but I do not want to edit those.
I have experienced this problem as well (noted by the bold text)
Sometimes K-Manager doesn't seem to recognize that you're selecting something, so when you use a hotkey to adjust your selection, nothing happens. When this happens to me, the items I want to edit do not get highlighted to indicate the selection.
Note that I usually will click a value then use Shift+Arrow keys to expand the selected area. If I click a single value, I'm able to edit it, I just can't select multiple cells.
Restarting K-Manager fixes this issue but I have no idea how it is triggered.
kidinatype_S wrote:Now with the 1.4.5 update all my tables show only low speed index!
That is because you have saved with V1.4.4 and reloaded with V1.4.5. You should start a new calibration load from loading a pre V1.4.4 calibration and then either copy/paste in values which you have altered, or use the 'Import From Calibration' to import tables. Don't update indexes if you do this.
tiger
Post by tiger »
Thanks for the update!
kidinatype_S
Post by kidinatype_S »
That was tedious, but fixed, thanks for the info.
contectr
Post by contectr »
I have installed the new 1.4.5 beta version and i look about the Knock table but i don't see the boost columns..why??
how can I change the values of knock when the engine is on boost??
Honda Ep3 stock k20a2 jrsc
Hondata wrote:Knock tables are not expanded (ie there are no boost columns for them).
contectr
Post by contectr »
Thanks Hondata, you are planning to implement the tables in future versions?
kidinatype_S
Any chance we would get Temp. comp. for boost, like the S300 has with colder IAT it takes duty cycle away, and warmer temp. it adds duty?
doms22
No closed loop with V1.4.5. ? euro ctr ecu pra
Post by doms22 »
I don t have a closed loop With v1.4.5.
I watch all the parameters but nothing! still in open loop!
You have the o2 heater disabled. This cannot be disabled when you run closed loop.
doms22
o2 heater no disabled
Post by doms22 »
in my parameters closed loop , o2 heater is no disabled
sorry, must have had a different KAL already opened when I looked. You need to post datalogs showing this then.
doms22
s trim always 0
Post by doms22 »
s. trim alwlays zero
voila a file using a different kal with 1.4.5 ..
When was it reading last?
What happens if you go back to the non-beta version of software?
doms22
with v 1.4.1
Post by doms22 »
ok with 1.4.1 close loop ok
