VTC on decel
Re: VTC on decel
Can you double check that Rev20 loaded properly? Something doesn't seem right, it's super rich all over, especially under WOT.
Where did you get the RDX's from?
Re: VTC on decel
I saw that. I got them from RYwire.com. it also said they were in the 90% duty cycle range. the boxes are from honda
08 civic si proline springs koni orange Hondata hybrid racing CAI with larger throttle body and peeling and faded Blue paint
Re: VTC on decel
Yeah double check that Rev20 uploaded then. Something is wrong somewhere.
Re: VTC on decel
re-upload and saw the same thing on the app, went rich as soon as I floor it. Do you still want me to upload the datalog?EFICU wrote: Sat Dec 04, 2021 8:43 pm Yeah double check that Rev20 uploaded then. Something is wrong somewhere.
Re: VTC on decel
No. Let me look over the other one and make changes based on that. I’ll look over some other RDX cars I’ve done and see of there are drastic differences or something.
Re: VTC on decel
So looking at other files you have less fuel than some. I think I might have found the issue, which would be weird, but possible. GIve this one a try and let's see how it looks.
Re: VTC on decel
Just keeps feeling better.EFICU wrote: Sat Dec 04, 2021 11:10 pm So looking at other files you have less fuel than some. I think I might have found the issue, which would be weird, but possible. GIve this one a try and let's see how it looks.
MM082001.SD.V3.Rev20.1 (Blended)(RDXs).fpcal
Re: VTC on decel
Yeah I guess my silly error in the calibration was the problem. Now it looks good. I made a few adjustments for fuel in this next one. Feel free to have fun with this next one, it's plenty safe now, so we'll see how it looks.
Re: VTC on decel
What is going on around 6000 to 6400 rpm? It just has a weird up and down on the air fuelEFICU wrote: Sun Dec 05, 2021 12:44 am Yeah I guess my silly error in the calibration was the problem. Now it looks good. I made a few adjustments for fuel in this next one. Feel free to have fun with this next one, it's plenty safe now, so we'll see how it looks.
Re: VTC on decel
Hard to say, most likely just making the adjustments for the new injectors. They've definitely changed the shape of the fuel tables a little in those areas. Could be a product of all the little changes you've made too, hard to say. Here is the next one. We should be pretty close on this one, we'll see though.
Re: VTC on decel
EFICU wrote: Sun Dec 05, 2021 2:10 am Hard to say, most likely just making the adjustments for the new injectors. They've definitely changed the shape of the fuel tables a little in those areas. Could be a product of all the little changes you've made too, hard to say. Here is the next one. We should be pretty close on this one, we'll see though.
Re: VTC on decel
Looks really good. I made a couple 1% and half percent changes to this one to tighten it up just a bit more. Other than that though, it's pretty much there. No knock too which is great.
Re: VTC on decel
Feels great. I hope Sac raceway doesn't get rained out. I might go and see how close to 13's I can get.EFICU wrote: Sun Dec 05, 2021 5:44 pm Looks really good. I made a couple 1% and half percent changes to this one to tighten it up just a bit more. Other than that though, it's pretty much there. No knock too which is great.
MM082001.SD.V3.Rev23 (Blended)(RDXs).fpcal
Re: VTC on decel
Overall it looks good. We had a few knock in two areas, so I made some adjustments for that. See how this one goes.
Re: VTC on decel
Good day at the track. Only 20 or less cars running today. Knocked another tens off, but bogging the launch and grinding second kept me from anything better. I lowered the launch to 3800 and lowered my tires to 25psi. I should have done one or the other. Still a fun day.EFICU wrote: Thu Dec 09, 2021 11:33 pm Overall it looks good. We had a few knock in two areas, so I made some adjustments for that. See how this one goes.
MM082001.SD.V3.Rev24 (Blended)(RDXs).fpcal
On the drive home notice the flashing engine light for knock. Only at light throttle. It's running great and it seems to be getting better fuel economy. Almost 25 MPG, even with going to the track and a few hard pull in between.
