Ok, I got everything rotated and it's still all over the place. Could I have the wrong sensor??? I am finding 2 different part #'s, the one you recommend 13940 and the one I think I ordered.EFICU wrote: Wed Nov 24, 2021 11:35 pm It could be a leak. The fact that it's rich on one pull and way lean on the next means something isn't right. It was hard to tell from the photos, but is the primary o2 sensor horizontal in the pipe? It's not going south to north by chance?
VTC on decel
Re: VTC on decel
08 civic si proline springs koni orange Hondata hybrid racing CAI with larger throttle body and peeling and faded Blue paint
Re: VTC on decel
What website is that screenshot from, I can't find anything for that part number?
Re: VTC on decel
Parts geekEFICU wrote: Sat Dec 04, 2021 12:10 am What website is that screenshot from, I can't find anything for that part number?
Re: VTC on decel
The fact that Parts Geek is the only site I see that shows that part number makes me a little nervous. When you go to Bosch's site, it shows the 13940 is the number to get for the upstream https://www.boschautoparts.com/g/oxygen-sensors.
Parts Geek does show the 13940 though, https://www.partsgeek.com/ss/?i=1&ssq=bisch+13940.
Re: VTC on decel
they definitely sent me the wrong sensor. I'll have a datalog shortly. Far right is the Bosch.
Re: VTC on decel
bottom is bosch
Re: VTC on decel
Interesting. We’ll see how it looks.
Re: VTC on decel
I think that was it. Things look a lot more consistent. The Denso works.
Re: VTC on decel
Yea it definitely looks a lot better. I made some fueling adjustments based on that datalog.
Re: VTC on decel
EFICU wrote: Sat Dec 04, 2021 5:23 pm Yea it definitely looks a lot better. I made some fueling adjustments based on that datalog.
MM082001.SD.V2.Rev19 (Blended)(Sport)(SpeedoAdjust).fpcal
Re: VTC on decel
I'll do a datalog, then I will be ready to put in the RDX injectorsEFICU wrote: Sat Dec 04, 2021 5:23 pm Yea it definitely looks a lot better. I made some fueling adjustments
Re: VTC on decel
Okay sounds good. I’ll put together the RDX file then. You'll need that to start it.
Re: VTC on decel
Everything is feeling great!EFICU wrote: Sat Dec 04, 2021 5:42 pm Okay sounds good. I’ll put together the RDX file then. You'll need that to start it.
Re: VTC on decel
Looks good. Still needs some work, but since we're moving to RDXs we'll just start there.
Here is the first one for the RDXs. Take this one for a 20-30 minute drive and only do one WOT pull in third gear so we can get some data before you have too much fun with it. In theory, adding RDX injector on a tuned car should yield very close fuel results, we still want to be careful until we get some data.
Re: VTC on decel
That's feeling better. The kick at part throttle when it hit VTEC is much more noticeable.EFICU wrote: Sat Dec 04, 2021 6:27 pm Looks good. Still needs some work, but since we're moving to RDXs we'll just start there.
MM082001.SD.V3.Rev20 (Blended)(RDXs).fpcal
