SManager software requests
rev hard
Re: SManager software requests
Post by rev hard »
Bring back settings for the strain gauge, would be great
Johnny_9
Post by Johnny_9 »
Change is have a X-Y plot of "rpm" vs "rate of change of rpm"
Muckman
Post by Muckman »
Closed loop boost control
Integra GSR 13.5:1 GT30R 597hp
Evo9 MR SE
b16bboss
Post by b16bboss »
5) Add-on knock module (knock window, frequency, time intergral etc, individual cyl closed loop knock control)
This would be great
coupe-r
Post by coupe-r »
DIRECT SERIAL LOGGING (Innovate products)
That is all......
Other products been doing this for YEARS. Takes out the ground offsets, noise etc. Live tuning is MUCH better and faster sample rate.
S300 V3 you say? Well you can't log the Digital air fuel ratio into the fuel tables for lambda % offset and real time tuning using the digital input Correct?
Or can I using Sensor Overlay Digital input?
I can't use closed loop digital input but that's because the input needs to go through D14 which is fine...
This is all SOOO much easier if you guys just use their serial protocol into SManager....
Luke
Post by Luke »
Boost Control via external knob:
Since the S300 has that boost control option it would just be great, if you could setup your maximum boost (in percent of boostcut) via an external knob hooked up to the V3.
if anyhow possible with some feedback in the dash cluster. so setting the boost to 40% of maximum boost the VSS goes to 40 for a moment and then back to the VSS signal from the transmission.
just a thought I had.
kind regards Lukas
Johnny_9
Data Log Export (CSV) - ECTc AITc
Post by Johnny_9 »
Can we get the ECTc and IATc variables exported in the CSV?
I am doing and X-Y-Z plot of A/F,ECT vs ECTc to optimise cold starts and warm-up enrichments
Re: Data Log Export (CSV) - ECTc AITc
Johnny_9 wrote:Can we get the ECTc and IATc variables exported in the CSV?
Done
Johnny_9
Post by Johnny_9 »
Done
Thanks; can you kindly post the Beta!
The next release is due in the next couple of days.
b16bboss
Post by b16bboss »
Can we have something in protection that can pull timing when it sees voltage or don't from an input like a knock module
AREA876
Post by AREA876 »
Still would love to have more adjust ability over target Lambda table than just three points
AREA876
Post by AREA876 »
Would love to be able to view target Lambda in display and be able to do a graph trace of both target and actual Lambda
skullbasher
Post by skullbasher »
Would it be possible to add a feature to the quickspool section that allows you to change the fixed amount of duty cycle (99%) when triggered? This would give us a bit more tunability of the powerband/boost curve. Thanks.
skullbasher
A secondary quickspool table would also be convenient for the high boost table.
