I wonder if you had two of the same cars with the same mods and how the tunes would be. I'm sure they would be close but I also think there would be some differences if you really got into the nitty gritty of it all. Then send them to different elevations and see how they would perform. Be interesting to see. I do remember taking my old sedan through the mountains and it did seem gutless due to the higher elevation.EFICU wrote: Sun Aug 15, 2021 11:04 am I'm sure it's a combo of parts and cams. Honestly could be a number of things. It shows you that the more you know, the less you know. Haha. I used the strategy from your car thinking I had found a strategy for higher elevation cars, but then it didn't work on his. It's definitely something I will keep in the back of my mind though moving forward. It's always good to learn something new you might be able to utilize on all these cars. Yeah the TSX has a ridiculously high vtec RPM as well. Shows you why having it tuned is important for getting the most out of it safely, and why a one size fits all basemap isn't ideal.
That's good that it's smooth at 3600. That is why I keep the cam angle smooth with no large jumps, that way the cam angle can follow the cam commanded nicely. When you have large jumps in cam angle, it makes things a little jerky.
Yeah the knock that showed up is in a couple new areas, so again they are probably just random ones, but I went in and made some changes. I also added the sport pedal map in this next one. We're in a good place for you to see what you think about it. Take this one for a spin when you can and see if you noticed much of a difference with the pedal map.
afauser.SD.V2HR.Rev10 (Blended)(Vtec3600)(Sport).fpcal
I'll drive this one for a few days and see how things go. I had a couple knocks pop up on a short trip from the store but I wasn't running a log at the time. My drives are usually 10-15 minutes. Work and most places I go to are quite close to home so no real chance to test it out yet. Thanks
