Page 2 of 2
Posted: Fri Aug 07, 2009 4:46 am
by gottabfast
Yes, the OBDI ECU does not have a C connector, but the harness on the OBD2 car does.
So apparently the Honda drawing for the ECU does not label the pins the same way...
D10 on that link is D18 on the Honda drawing, so that's the mix-up I've been encountering!!!
Thank you da_dude!
Wideband Install
Posted: Thu Apr 29, 2010 1:11 pm
by blacksi76
My Tuning guy wants to tune my car in open loop only, and not use the factory O2sensor, my car is a 2000Civic SI OBD2B , and I have a brand new Hondata P28ECU with the OBD2B Connector built in, so I have to wire the wideband analog wire into factory O2 sensor wire in the wiring harness.....I am having difficulties figuring out what wire in my OBD2B harness to use as the ECU itself is an OBD1.....Any help???
Posted: Thu Apr 29, 2010 2:09 pm
The diagrams in our help file are correct as viewed from the terminal side of the plugs.
http://www.hondata.com/help/smanager/ecuconnectors.htm
OBD1 pinouts for the inputs and outputs can be found in the link above.
Posted: Thu Apr 29, 2010 5:45 pm
by blacksi76
Ok so according to the OBD1 ECU connector diagram from the help section link you posted, pin D14 is the O2 input, but my harness is OBD2B, so I am having a hard time figuring out what wire on my harness male plug to wire my wideband analog input into...The factory OBD2B ECU has a blank D connector, but the new Hondata p28 ECU I bought with the built in OBD2B conversion has pins in the D Connector....
Posted: Fri Apr 30, 2010 9:24 am
scroll down on that link
Found it!!
Posted: Fri Apr 30, 2010 11:03 am
by blacksi76
Its was C16- primary O2 sensor wire ( White ) on my OBD2B harness
Re: AEM Wideband through D10 ELD
Posted: Tue May 03, 2016 11:29 am
by gabrielsousa
i have my wideband on d10 ELD,
but my circuit stop working, same times works.... same time not.
looks like a condenser problem
can you tell me if theres a condenser on ELD circuit ? and which is ?
Posted: Tue May 03, 2016 11:51 am
What do you mean by a condenser?
Posted: Tue May 03, 2016 11:55 am
by gabrielsousa
Spunkster wrote:What do you mean by a condenser?
Capacitor , sorry
Posted: Tue May 03, 2016 12:43 pm
There are only 2 resistors which should be removed.
Posted: Tue May 03, 2016 8:46 pm
by gabrielsousa
i know , r136 and r138, i have this working for 2 years.
and now sometimes i have good/right/correct readings, and sometime not ... looks like a bad capacitor :(
Posted: Wed May 04, 2016 9:26 am
You could try replacing all the electrolytic capacitors on the ECU: https://www.hondata.com/accessories/capacitor-kit
Posted: Thu May 05, 2016 7:34 am
by gabrielsousa
Spunkster wrote:You could try replacing all the electrolytic capacitors on the ECU: https://www.hondata.com/accessories/capacitor-kit
thanks a lot ,
I had already replaced. a year ago.
i will replace c18 again
