Page 2 of 2
Posted: Wed Aug 12, 2009 10:45 pm
by edomund
It will blink on for a split second & then remain off for several seconds then blink again. I don't see a clear pattern. What should I be looking for?
What is the correct status of the light?
Any thoughts about what I posted?
Thanks,
Ed
Posted: Mon Aug 17, 2009 12:53 pm
by edomund
Any ideas?
Posted: Mon Aug 17, 2009 3:26 pm
Do you know anyone near you that has a K-PRo in their S2000 that you can swap ecus with for testing?
Posted: Tue Aug 18, 2009 10:51 am
by edomund
I posted a thread on the s2ki Sacramento area sub forum, so we'll see if anyone does. But I already know most of those guys & none of them are running Kpro.
Could you please tell me the correct status of the adapter?
Without knowing that how can I tell if it's correctly lit?
If I can't find someone with a Kpro near me can you guys send me another Kpro to try?
Posted: Tue Aug 18, 2009 11:42 am
When it was here it was behaving as it should this is why I would like you to try it in another vehicle if possible. The only other person that had issues with this had air bubbles in his cooling system and had to bleed it.
Posted: Tue Aug 18, 2009 1:04 pm
by edomund
I will try to find someone, as this would rule out any problem with my vehicle.
What doesn't make sense is I didn't have a problem when my factory ecu was in & I haven't touched the cooling system since I changed ecu's.
Also when I sent it in the 1st time the adapter board light NEVER came on (ect ALWAYS read 1 bar) & now it works sometimes.
Also if it was air bubbles or something to do with the sensor wouldn't the voltage change when the ECT gauge dropped off? The voltage is constant even when the ect gauge drops down to 1 bar.
Again, what is the adapter light supposed to do? Is it supposed to stay lit all the time?
Edit:
I think I may have found someone in my area.
Posted: Thu Aug 20, 2009 11:15 am
by edomund
Nevermind the guy is running AEM who volunteered.
What can I do if I can't find anyone?
Also can someone please tell me what the adapter light is supposed to be doing when operating correctly?
Posted: Thu Aug 20, 2009 11:28 am
Please just send it back to us an we will arrange a test in a vehicle here. Please send it using the same RMA number you were given before. The status of the LED will not help trouble shoot anything at this time.
Posted: Thu Aug 20, 2009 2:23 pm
by edomund
OK thanks I appreciate it.
I'll give you guys a call as to when I'm sending it so you can set up the test vehicle.
thanks,
Ed
