Page 2 of 3
Posted: Thu Feb 05, 2009 2:12 pm
by cranny
Posted: Thu Feb 05, 2009 4:25 pm
by perico_asesino78
Cranny... what do you think about
PLX DM-100 DM100 Wideband o2 HD Display Gauge AEM Turbo
Posted: Thu Feb 05, 2009 11:21 pm
by cranny
im sure thats fine , has to be a 0-5 volt range sensor. youd have to ask spunkster which exact one they recommend.
Posted: Fri Feb 06, 2009 6:51 am
by perico_asesino78
Cranny I bougth an AEM wideband...
Posted: Sat Feb 07, 2009 8:26 pm
by cardinal811
FIRST question throws me off. HOW MUCH BOOST DO YOU PLAN ON RUNNING. Should of said, how much WHP are you searching for. Guys you can have a 100whp car with 25psi of boost with the ignition retarded to the max. Depends on the cfm of the turbo and the ignition adavance. Anytime some one just asks HOW MUCH BOOST DO I RUN I just look at them in a retarded fashion and say something in KPA and they act like they know exactly what it means. COMEDY
Posted: Sun Feb 08, 2009 5:49 pm
by perico_asesino78
Ohhh... ok.... 350 or more WHP
Posted: Thu Feb 26, 2009 3:33 pm
by perico_asesino78
Hi, Russ sent me a map and I modified it for my car because my city (Quito) is 9.200 feet over the sea level and have less oxigen.... please check it... thanks
Posted: Thu Feb 26, 2009 3:35 pm
by perico_asesino78
I put a wideband AEM the last week
Posted: Thu Feb 26, 2009 7:20 pm
by cranny
wire it into S300.
Posted: Fri Feb 27, 2009 6:49 am
by perico_asesino78
Yap... I did it...
Posted: Fri Feb 27, 2009 7:04 am
by cranny
did you wire it into the D10 pin of the S300?
Posted: Sat Feb 28, 2009 10:56 am
by perico_asesino78
D14
the next week I'll put a Hondata Boost Control solenoid
Do you know if is necesary to calibrate the AEM wideband? in the rear of the gauge have a screw....
thanks!!!
by perico_asesino78
the ecu is a P06
Posted: Sat Feb 28, 2009 5:44 pm
by cranny
they come pre calibrated. dont fuss with it. the gauge is correct.
Posted: Mon Mar 02, 2009 6:59 am
by perico_asesino78
Thanks Cranny... my wideband with the Rusty's map was on 10,00 and the car was slow at high RPMs... I put less fuel and the car run better... and I can see 11 at the wideband...
