need help with jdm k20a tune
HELLRAZR
Post by HELLRAZR »
version 1.2.3.5, but everytime i try to dload the newer version it gets half way thru then tells me error downloading...
HELLRAZR
Post by HELLRAZR »
got the new version at last, and got the launch limiter to work... the 23 knocks prior to the datalog, were from lower rpm's, it knocks between 2k rpm and 3k rpm even after the last map given to me, it also knocks near redline right before cut off. i haven't had time to do a run yet, it's just every time i do a 4th gear run it doesn't knock as much as regular driving. i will try and get a datalog of all the knocking, i personally really liked the map before last, that last one given to me made the car quite weaker, and i just found out that the i had an exhaust leak right before the primary O2 sensor which explained the unbelievable gas consumption.
thanks again.
fonz600
Post by fonz600 »
No probs mate. If you want me to have a look at it then just drop a datalog to me and I'll help. Fix the exhaust first though.
HELLRAZR
Post by HELLRAZR »
ok i just drove my car around with the datalog running, i wasn't able to get a log on the 2-3k knock at around 30% throttle. this is using the last map given to me in this thread.
a friend of mine has a european type r with a jdm CTR k20a swap, he just got k-pro a couple of days ago, we uploaded the same map on his ecu, and there was no knocking what so ever.
his mods are pretty similar to mine with these exceptions, i have 3" straight pipe, he has 2.5" straight pipe, he has the original airbox, i have aem v2. for those who are curious, we did a few runs from standstill and from roll and it was head to head.
HELLRAZR
Post by HELLRAZR »
here's a log with the 2-3k knocks
fonz600
Post by fonz600 »
I'll have a look tonight mate but each car is different and some are more sensitive to knock than others.
cranny
Post by cranny »
heres a fix for you temporarily to kill the knock. if you ask me , you need alot of work done to your calibration dude , theres alot i would change. if your willing i can help you as well.
heres what i want you to do , listen carefully. load this map i give you onto the ecu , make sure its in open loop. do about a 30 minute datalog for me , no WOT at all. drive normally , but try and get in all gears in different speeds/revs. once you have this datalog , come back and post it for me ok. your part throttle tuning is way off. your car is running rich as well in medium load range. we can fix it all.
fonz600
Post by fonz600 »
His map hasn't had any part throttle tuning or fuel curve smoothing done mate as he wanted a break from tuning/datalogging.
From memory I think I pulled some ignition at part where he was knocking but it was never eliminated.
Hope you get it sorted for him as I've been too busy to look at it.
HELLRAZR
Post by HELLRAZR »
thanks alot people, i really appreciate it. i wish you tell me what you've done so i can learn, or get an idea... but if you don't want to give your secrets that's fine too.
once again thank you i will try this and do the run you asked me for asap...
cranny
Post by cranny »
no secrets at all buddy , any questions , ask away.
i changed your vtec point to 4k , from 3800. i changed your cam angle on low cam to start it toward 50degrees for high cam engagment. i set your entire low cam cruising range to 30 degrees. when you get me this datalog , i can tune your part throttle part of the map , might ned one or 2 more to get as close to perfect as possible. once were done that , i want to play with your high cam cam angle , cause it seems your running less timing than you should be able to. may be cause your running too much cam. anyways , work in progress , lol.
cranny
Post by cranny »
dude... where did you go? lol
fonz600
Post by fonz600 »
cranny wrote:dude... where did you go? lol
He does take a few days sometimes mate. Don't think he comes on the forum that much.
HELLRAZR
Post by HELLRAZR »
i'm so sorry for the delay... it's just been extremely busy, flying all over the place, plus the car's in the shop for a good couple of weeks, getting a paint job and the passenger side mount broke for the 2nd time in 3 months, waiting for the avid mounts to get here before i can drive it. but i was able to get the log you asked me for before all that happened. this last map you gave me, well, it knocked more than the previous ones i've tried... i will upload the file tomorrow as my laptop is in my office.
once again sorry for the delay
HELLRAZR
Post by HELLRAZR »
here's the log file...
cranny
Post by cranny »
you need to post the fuel map too bro. i have that datalog now but you need to post up the fuel map i gave you as well.
