Page 2 of 3
Posted: Fri Aug 22, 2008 7:15 pm
by S2KPRO
Spunkster wrote:We are looking into a permanent fix for this and will update you when we have a resolution.
I should add that when I left my tuners shop my CEL was on. I then went to the gas station filled up and it never turned back on for the 15km drive to my house. The next day I am driving to work and the light comes on within 15 seconds of driving.
I went back to my tuner today to have it scanned and the same code came up again.
Not sure if this bit of detail will help, hopefully it can lend a hand in understanding the problem.
Posted: Mon Aug 25, 2008 8:34 pm
by S2KPRO
Are there any updates from anyone at Hondata that they can provide, any insight to this fix this problem at all? I would hate to go back to my mechanic and have them try and troubleshoot and spend more money and time etc.
Posted: Tue Aug 26, 2008 10:45 am
1. Download the beta version: http://www.hondata.net/updates/KManagerV1-2-9.exe
2. Update ECU.
3. Datalog from a cold start as soon as the engine fires.
4. If there are problems, post the datalog here.
5. Don't panic.
Posted: Wed Aug 27, 2008 4:58 am
by S2KPRO
Hondata wrote:1. Download the beta version: http://www.hondata.net/updates/KManagerV1-2-9.exe
2. Update ECU.
5. Don't panic.
The software that was used for my tune was v. 1.2.3.5 I assume the one you have posted above is different than the one I have?
Thanks for your help.
Posted: Fri Sep 12, 2008 6:53 pm
by Garrett_si
I finally installed and test my own S2000 K-pro on my 2004 s2k
the problem is the same
O2 sensor high voltage
and after disable 02 sensor, 02 sensor heater, and using secondary...
I have the 02 sensor low voltage
I understand that Hondata try to find a way to fix it
But I think I will convert mine to use the RSX wideband 02 sensor
Posted: Mon Sep 15, 2008 2:10 pm
Please try the beta version above.
Posted: Sat Sep 27, 2008 7:42 am
by Garrett_si
I try it today when tuning my car on the dyno and with de 1.2.6 version the probleme still the same
low voltage 02 sensor CEL code
Posted: Mon Sep 29, 2008 9:39 am
1.2.6 is not the new version or the beta listed above.
Posted: Mon Sep 29, 2008 2:11 pm
by Garrett_si
sorry I used 1.2.9 that you post here
Posted: Mon Sep 29, 2008 2:12 pm
What exactly have you done once you downloaded the new software?
Posted: Mon Sep 29, 2008 2:20 pm
by Garrett_si
Spunkster wrote:What exactly have you done once you downloaded the new software?
I installed it to replace the last version
I open my cal, and upload it in my K-pro
Posted: Mon Sep 29, 2008 2:29 pm
With your calibration loaded and a datalog of the problem go to File and click on email. This will email us a detailed problem report.
Posted: Mon Sep 29, 2008 2:39 pm
by Garrett_si
Spunkster wrote:With your calibration loaded and a datalog of the problem go to File and click on email. This will email us a detailed problem report.
Ok
My outlook open when I did it, and there is no email adresse wrote
Posted: Mon Sep 29, 2008 2:59 pm
support at hondata.com
Posted: Mon Sep 29, 2008 3:21 pm
by Garrett_si
Send
