Posted: Thu Apr 17, 2008 8:44 am
So. The ignition retard bug has been solved by deleliting the [IATRetardLow] and [IATRetardHigh] in the .kal file. Thanks nzitr - this helped much.
Regarding other bugs as engine stucks. We have tried to retune the ecu but the result was the same. We have inspected and removed skunk 2 cams, the runout of intake cam was not similiar to the exhaust cam and it was not smoth. But the were no beat of the cam, and all the other parts of the gas distribution mechanism look fine. After inspection we have installed stock cams, and everything became normal. So it was a problem of the intake cam. The cams will be send to skunk 2 for further inspection.
Thanks hondata, that was a mechanical problem. But we still do not understand, why this happend and why this occured only for RPM no more than 3000. We still do not understand why the MAP sensor was showing about full load with TPS only at 14%.
Also we have cheked Skunk 2 exhaust cam gear with stock cams at 3 degrees - loss of power at high rpm, but the vtec acts harder :)
One more thing. Please look at the log (the .kal is also atached):
What is happening with the ignition at 3-5 sec ? And A/F is suddenly falling too...
Just to remeber, now the specs are: K20A2, RBC intake, toda mani, custom catback, stock cams, stock rsx (2002) ecu + kpro, skunk2 retainers and springs.
