SManager V1.3.4
Shmaa
Post by Shmaa »
Yes...
holset hatch
Post by holset hatch »
how do i update my current smanager when i can't connect my laptop to the internet?
i can put the updated version on a usb device, but then how do i get the smanager to recognize the update?
thanks.
91 honda civic
turbo ls/vtec
You download the software from our website and install it like you would install any other software.
holset hatch
thanks, thats what i ended up doing, for some reason i had it in my head that it was just an update to the previous version, not the entire program. :oops:
91 honda civic
turbo ls/vtec
hondapowaa
Post by hondapowaa »
hii
i have a question about de proportionnal tracing.
What signify the difference between the most clear case(white) and the most red case??
(scuse if my english is not really good i'm french)
does red = the most correct case (rpm/load) and white the lower??
Essentially, yes. The ECU is interpolating values, and the darker color shows the value with the strongest weighting.
eg with this table and an engine speed of 2800 rpm
rpm index 2000 3000 4000
values 10 20 30
the 2000 rpm cell to be shaded light (red/blue) and the 3000 rpm cell to be shaded dark (red blue). The ECU would then combine the lookup values of 10 and 20 with a proportion of (200/1000) = 0.2 * 10 = 2 and (800/1000) = 0.8 * 20 = 16 to give a lookup value of 18. Hope that makes sense.
JDC2TypeR
update smanager program has virus "Klone"
Post by JDC2TypeR »
the new version hondata smanager software has virus called klone. I installed it but it won't open and a box pop up and says that it's not able to execute to program. can you guys check on that?
