Page 2 of 5
Posted: Thu Jan 03, 2008 7:21 pm
by DOHCAccord
mike93hatch you cut em both and it now is a dead on match from your laptop to the actual reading of the wideband?
Plus what ecu are you using if i may ask, p28, etc.
Posted: Thu Jan 03, 2008 10:52 pm
by mike93hatch
DOHCAccord wrote:mike93hatch you cut em both and it now is a dead on match from your laptop to the actual reading of the wideband?
that is correct... running a p28
Posted: Mon Jan 07, 2008 3:04 am
by OTT
heres a good Question then... do HONDATA remove these two resisters from their HONDATA prepared ECUs ???? :idea: :?:
Posted: Mon Jan 07, 2008 5:39 am
by mike93hatch
OTT wrote:heres a good Question then... do HONDATA remove these two resisters from their HONDATA prepared ECUs ???? :idea: :?:
i would probably say no..
Posted: Mon Jan 07, 2008 10:46 am
These are not removed on any Hondata prepared ECUs.
Posted: Tue Jan 08, 2008 10:30 am
by OTT
in this case I have a different related question...
when D10 ELD is being used for wide-band input and ELD is disabled....
1. will removing the two resistors affect normal operation of the ECU?
2. Do I need to install a jumper to replace each resistor or can I simply cut the resitor out?
Posted: Tue Jan 08, 2008 12:38 pm
You only have to cut them. It will not cause any problems.
Posted: Sat Jan 12, 2008 4:09 am
by Teamdiesel
besides D10, what other methods can be used to connect the white wire of an AEM wideband to incoorporate it with the hondata s300?
Posted: Sat Jan 12, 2008 8:18 am
by laziebun
i just pop mine out and we'll see how it goes..................to be continue
Posted: Sat Jan 12, 2008 10:11 am
by laziebun
well im piss this damn thing...................well i took off the r136 and r138 and now my AFR is just showing 2.00 what the hell is going on someone help me!!!!!!!!!!!!!
Posted: Wed Mar 05, 2008 9:52 am
by OTT
laziebun wrote:well im piss this damn thing...................well i took off the r136 and r138 and now my AFR is just showing 2.00 what the hell is going on someone help me!!!!!!!!!!!!!
Free bump! I want to know whats happened!!? your got this sorted now??
Posted: Fri Mar 07, 2008 7:14 am
by Teamdiesel
me too, what happened?
Posted: Sat Mar 08, 2008 9:23 am
by planetspeed
Hope you had cut the correct resistors on the exact location..coz I had cut mine and the AF values are dead on with the gauge and laptop.
Posted: Wed Mar 26, 2008 3:27 pm
by hondapowaa
Jdm ecus have the d10/eld active.
But no one can tel me what resistor i must remove.
If i connect wideband directly i have a bad reading, impossible to down under 1/1,5v
So i connect on the d14 but i really want to know what are the resistors we must remove on the JDM ecu to work :)
scuse for my bad english, i'm not english :p lol
Posted: Wed Mar 26, 2008 4:25 pm
There are no resistors that need to be removed on a JDM ecu.
