Page 2 of 3
Posted: Thu Aug 30, 2007 10:10 am
What is the leanest it will read?
Posted: Thu Aug 30, 2007 12:43 pm
by hiperformance
Spunkster wrote:What is the leanest it will read?
I leaned it out all the way to 16 reads fine to there, 16 is where I stopped. is there a test or a check I should try?
Posted: Thu Aug 30, 2007 1:45 pm
Try decelerating and see how lean it will go
Posted: Sat Sep 01, 2007 3:23 pm
by hiperformance
Spunkster wrote:Try decelerating and see how lean it will go
Ok, on deceleration, in the display screen, the lambda value goes to 19.36, the plx goes to AIR.
Posted: Sun Sep 02, 2007 7:54 am
by Boosted91
Hi i had a question for both of you, cant you simply put the PLX in the place of the stock O2 sensor instead of running two sensors? and lastly my 02 sensor is not in the turbos stock location, but rather back a little ways in a bung on the exhaust pipe, it is a heated o2 sensor as well,so my last question would be since the plx is not heated could i still use it as the sole o2 sensor for the car? my worry is since it is located about a foot back from the turbo housing it may not get hot anough. thanks.
Posted: Tue Sep 04, 2007 10:23 am
A foot is too close and you will burn up the o2 sensor. The PLX is heated. Our instructions indicate how to wire the PLX to use it as the wideband and the narrowband to run in closed loop.
Posted: Tue Sep 04, 2007 2:57 pm
by hiperformance
Ok, I did the test, on deceleration, in the display screen, the lambda value goes to 19.36, the plx goes to AIR.
if i richen up the idle cells, lambda value in the display screen freezes at 11.82, if I keep richening it up, the plx and dyno afr's will continue in to the 10's but the data log stops at 11.82
your thoughts please.
Posted: Tue Sep 04, 2007 4:53 pm
Have you done anything not described in the PLX wiring instructions located on our website? Have you added any additional components (capacitors)?
Posted: Wed Sep 05, 2007 1:53 am
by hiperformance
Spunkster wrote:Have you done anything not described in the PLX wiring instructions located on our website? Have you added any additional components (capacitors)?
no additional components were added, i even printed the directions out and once i made the mistake of using the wrong pin for the input, i have gone over everything again. the only thing i did different is my + and - are pulled directly from the car battery terminals. just as a note: my offset voltage is -0.3
Posted: Wed Sep 05, 2007 2:04 pm
post the calibration and a datalog showing the problem.
Posted: Thu Sep 06, 2007 4:00 am
by hiperformance
I did 4 datalogs, maybe I am data logging wrong? I right clicked the graph screen, graph templates box poped up. I added AF with the color clMaroon to graph 3 so I could see what the AF was doing. I data logged and got nothing for AF? I did a dyno run and the car stumbled real bad, as it was stumbling, I looked at the PLX display, it was flashing 10.xx/rich, I looked at the lambda display from the hondata, 11.82. I did go to options then into sensor, the sensor set up box opened, I noted AF display min was 0.7 and display max was 1.4. is that correct, i changed display min to 0 and it made no difference? note: data log file ek1, I started the data log, then while idling, I the 4 idle cells and increased the fuel up to about 10.xx the back down to what it was. I pressed control "I" 25 times to achieve that then control "D" 25 times to bring it back to where it was.
Posted: Thu Sep 06, 2007 4:01 am
by hiperformance
Here is the dyno graph. That 11.66 shows 11.82 on the hondata display, but the plx screen and dyno read 11.66.
Posted: Thu Sep 06, 2007 9:36 am
Your graphs should be set to a min of 10 and a max of 20.
Posted: Thu Sep 06, 2007 2:16 pm
by hiperformance
Spunkster wrote:Your graphs should be set to a min of 10 and a max of 20.
I assume only the AF needs to be changed to a min of 10 and a max of 20.
thanks.
Posted: Thu Sep 06, 2007 2:20 pm
by hiperformance
ok, is this right? I go into sensor set up and only change the AF display min and max.
the rest I assume inj, map and rpm are all correct, sense it was pre-set.
thanks.
