Page 2 of 2
Posted: Wed May 30, 2007 11:38 am
by turbotypeR
Preccord00 wrote:
turbotypeR wrote:Why will it trhow a code? Is it because the temp will be too low or does it lose ground when it is taken out? It will still be hooked up, so if it loses it's ground, you could hook ground to the body of the sensor, but if it is because the temp was too low, I can see where it would throw a code.
It's because it loses a ground from the sensor, it's possible to just ground out the sensor if that's the route you want to go, I'm not entirely sure how the ECU will react to thinking it's cold all the time though.
i was just curious. for now, i am going to try and keep it cool until the newer version comes out.if that doesn't work,i will try the resistor method.
Posted: Wed Jun 13, 2007 7:03 pm
by turbotypeR
i cut the wire and ran it through a 386 ohm(not sure what the value is supposed to be,but it read 386 on a multimeter) resistor to ground and it put the ect right around 160 deg.the car is down right now,so i won't be able tell you how it works until later
Posted: Fri Jun 15, 2007 2:05 am
by crucian
Nice. I hope this works out for you and all of us.
Posted: Mon Jul 30, 2007 5:37 pm
by Upperguy
When is this issue going to be addressed on the software side?
Posted: Tue Jul 31, 2007 9:28 am
Should be in the next 6 weeks.
Posted: Wed Aug 01, 2007 8:28 am
by turbotypeR
Hondata wrote:Should be in the next 6 weeks.
Awesome! I can't wait. I am going to the dyno tonight to see how the resistor and boost control works
Posted: Mon Aug 27, 2007 7:51 pm
by Upperguy
Thanks for fixing this! I seen on the recent update that was have a table now.
let the nay-sayers be GONE hondata is just as good as any-other standalone!
