Detonation problems
scoobs187
Post by scoobs187 »
I put the engine from the 88 Integra the B20 Vtec in the 95 Integra I built and I went for a quick drive. I dataloged this I just don?t know what im reading (what it means).
jordancivic
Post by jordancivic »
Fueling looks good above 3500rpm FT, a little rich but nice flat line.
Are you still having det problems?
Hondata: on this datalog i have my MAP sensor set to PSI and im noticing that at idle he is reading 2/3psi. Is this just because PSI is positive pressure and wont show below around zero?
jordancivic
Hondata: on this datalog i have my MAP sensor set to PSI and im noticing that at idle he is reading 2/3psi. Is this just because PSI is positive pressure and wont show below around zero? When reading Mbar it reads fine, i know im missing something simple. Something to do with psi reads above atmospheric pressure or something? Thanks
set to read "/psi
scoobs187
Post by scoobs187 »
What is the max map you can set for the software
scoobs187 wrote:What is the max map you can set for the software
What do you mean?
