Page 2 of 2
Posted: Wed May 16, 2007 5:00 am
by Garrett_si
hyro wrote:i suppose that you already attach the white wire from your plxdevice to the ELD pin in the ecu?
yes because the AF on the K-Manager display works
Posted: Wed May 16, 2007 11:52 am
by Razathorn
You need to be graphing A/F with the right units / min and max values, not ELD.v on the graph. ELD.v is just the input. You don't even have A/F on your graph in the screen shots.
Posted: Wed May 16, 2007 12:59 pm
by Garrett_si
Razathorn wrote:You need to be graphing A/F with the right units / min and max values, not ELD.v on the graph. ELD.v is just the input. You don't even have A/F on your graph in the screen shots.
when graphing the AF it's stay at 0
Posted: Wed May 16, 2007 2:20 pm
by Razathorn
Do you have a datalog of this? What is the ELD.V at that time? Realize the settings for a/f in kmanager "will not stick" to the datalog. It is just allowing you to graph AF upon datalog review by using different inputs. It's not like using a given setting in kmanager for what sensor you are using will change the datalog. If you have ELD.V in your datalog, you can change your kmanager settings to display a/f VIA that at any time for any datalog you had ELD.V values stored in it.
Posted: Wed May 16, 2007 7:54 pm
by Garrett_si
datalog
Posted: Wed May 16, 2007 10:09 pm
by Razathorn
That datalog has 0.00v for ELD.V always. It looks like the sensor was not hooked up correctly at the time.
Posted: Thu May 17, 2007 4:20 am
by Garrett_si
Razathorn wrote:That datalog has 0.00v for ELD.V always. It looks like the sensor was not hooked up correctly at the time.
I think you don't understand
the AF display works
it's just the ELD display that don't
and Spkunster said it normal, K_manager dont make it possible at this time
Spunkster wrote:The graph is not currently showing the AF. A future release will probably address this.
Posted: Wed Jun 27, 2007 6:31 am
by Garrett_si
Does Hondata work on an update of the K-pro to make the ELD voltage display graph work?
Posted: Fri Jul 06, 2007 9:35 am
by Garrett_si
does the last update this week solves the problem?
