yes because the AF on the K-Manager display workshyro wrote:i suppose that you already attach the white wire from your plxdevice to the ELD pin in the ecu?
Datalogging AF graph problems
Garrett_si
Garrett_si
Do you have a datalog of this? What is the ELD.V at that time? Realize the settings for a/f in kmanager "will not stick" to the datalog. It is just allowing you to graph AF upon datalog review by using different inputs. It's not like using a given setting in kmanager for what sensor you are using will change the datalog. If you have ELD.V in your datalog, you can change your kmanager settings to display a/f VIA that at any time for any datalog you had ELD.V values stored in it.Garrett_si wrote:when graphing the AF it's stay at 0Razathorn wrote:You need to be graphing A/F with the right units / min and max values, not ELD.v on the graph. ELD.v is just the input. You don't even have A/F on your graph in the screen shots.
Garrett_si
Garrett_si
I think you don't understandRazathorn wrote:That datalog has 0.00v for ELD.V always. It looks like the sensor was not hooked up correctly at the time.
the AF display works
it's just the ELD display that don't
and Spkunster said it normal, K_manager dont make it possible at this time
Spunkster wrote:The graph is not currently showing the AF. A future release will probably address this.
Garrett_si
Garrett_si
