Page 2 of 2
Posted: Thu Mar 01, 2007 7:09 am
by hyro
CivicVTi wrote:I think you can. Haven't tried that though. But I think the extra resolution will just increase tuning hassle and time.
i just tried it and it is possible.
time will increase, but the estra resolution will give you more precision, me thinks.
in MAPxRPM, the idle was in column 3-4 and when we release the gas, reads in columns 1-2.
now with TPSxRPM, how can we reproduce this behavior?
Posted: Thu Mar 01, 2007 4:45 pm
by CivicVTi
You cannot. Both idle and release throttle load reading will be 0%. You should not care about this though. It is normal.
Posted: Fri Mar 02, 2007 12:37 am
by hyro
CivicVTi wrote:You cannot. Both idle and release throttle load reading will be 0%. You should not care about this though. It is normal.
ok. thanks.
Posted: Fri Mar 02, 2007 12:40 am
by hyro
it will be interesting to modify the maximum MAP for closed loop to maximum TPS for close loop.
what do you think?
Posted: Fri Mar 02, 2007 3:54 am
by CivicVTi
This is done automatically. If you have:
Min MAP:0kpa
Max MAP: 100kpa
Max MAP closed loop: 50kpa
THen your max TPS closed loop will be 50%.
Posted: Fri Mar 02, 2007 6:32 am
by hyro
CivicVTi wrote:This is done automatically. If you have:
Min MAP:0kpa
Max MAP: 100kpa
ah, ok. it is calculated like this.
tps closed loop = (Max_Map - Min_Map) * (max_closed_loop/100).
Posted: Tue Mar 20, 2007 1:33 am
by hyro
civicvti, which values did you use on TPS columns?
you say that we need more resolution in lower tps openings and less resolution in higher openings.
would you post these values to take a reference ?
thanks in advance.
Posted: Tue Mar 20, 2007 11:35 am
by CivicVTi
It's really up to you. I think I used:
1%, 3%, 5%, 7%, 10%, 12%, 15%, 20%, 30%, 40%, 50%, 75%, 100%
With boost values of course (13 total columns)
Posted: Wed Mar 21, 2007 1:20 am
by hyro
CivicVTi wrote:It's really up to you. I think I used:
ok, thanks. just to take a reference from a succesful tuning.
