SManager V1-1 Beta
Can someone post either a screen shot of the sensor overlay and wideband lambda settings or post the SManager.ini file?
Silverbeast
Post by Silverbeast »
Here is mine...
Remove .skl
ridewhencan
Post by ridewhencan »
Silverbeast wrote:Here is mine...
Remove .skl
How do you view this? I want to know what to look for when I get my s300, hopefully by this weekend.
Can you post SManager.ini ?
Silverbeast
Sorry, posted the wrong one....
Try this and let me know if you need any other info..
Thanks,
Ricky
OK, problem is fixed. Re-download and install the beta version (the version number is still V1.1).
Download here
Also I fixed the lambda tracing color.
Silverbeast
Thanks a lot. I will test this evening and update the status.
D@nny
Post by D@nny »
the realtime lamda works again. thanks...
I am however still having a problem with the ect compensation and the IAT compensation...both dont seem to do anything at all. no matter what values you enter it does not change the air fuel at all
Also switching over to the beta made the entire partial throttle map rich but didnt seem to affect the boost tables as much...I have yet to check the high boost due to rain... the was 30 percent rich
sq_creations
Post by sq_creations »
I am having a problem with my s300 freaking out in high rpms. I had my redline set to 7800 and @ 7000 the tac and display would go all over the place. I try setting the revlimit to 7000 and it freaked out @ 6000 rpms. Tonight I will try to raise the revlimit a see what happens. I emailed my skl to hondata support.
Can you explain what the overrun fuel cutooff feature does? Should it be set near the revlimiter?
taken straight from the Help file:
Fuel Cutoff
This controls the rpm point where the injectors are cutoff at very low throttle openings.
sq_creations
Thanks, I must have missed it.
Any ideas on the high rpm problem?
Make sure the rev limit is set to 'fuel cut' only and there are no launch or shift limiters active.
Post the calibration and datalog if there are any more problems.
Jeezerb18c
Post by Jeezerb18c »
So how long until all the Hondata glitches are fixed??? :?
sq_creations
Im not sure if i should start a new thread but.....
So i figured out a way around it. With the rev limiter set to 7k the tac freaks at 6k. I set the rev limiter to 10k and took the car to 7k without a problem..
here is a datalog of both runs and my skl
sq_creations
I don't know whats going on :( ....I took the car to work this morning and the rpm weirdness was back @ 6k even with the 10k rev limit.
I am going to try a diffrent distrubutor because that was suggested to me.
