Page 2 of 5
Posted: Sun Jul 31, 2005 10:34 am
by SiK LiL pLaYa
02SilverSiHB wrote:SiK LiL pLaYa wrote:02SilverSiHB wrote:
you're joking right? you're asking if the boost control works on NA?
THat is NOT what I'm asking. I was wondering if the fuel and ignition correction would work on NA as of right now. I know Hondata planned on including this in KPRO so am wondering if this is it or if its something else for NA cars. I guess I should have been more specific.
My BAAAAD.
lol! sorry man..I was like..uhhhhh, wtf?
All good, that was all my badd lol.
Posted: Sun Jul 31, 2005 1:42 pm
by SiK LiL pLaYa
Nevermind my question. I see that this version has IGNITION and FUEL adjustability for NA cars. Thanks HONDATA.
Posted: Sun Jul 31, 2005 4:16 pm
by Razathorn
I can't imagine that the per gear adjustments would be specific to running boost...
Posted: Sun Jul 31, 2005 11:04 pm
by Dominic..
Kpro boost controller works in EUro Kpro?
and example valve selonoid from avcr could use with kpro?
Posted: Mon Aug 01, 2005 8:16 am
by k20tuRbo
Can someone help with the install of the solenoid? I already ordered the parts.
also is there a hi low setting? I need to run 20psi at the track, I guess I just need 2 calibrations?
Posted: Mon Aug 01, 2005 9:13 am
You really need to read the help file. There is a low and high setting, triggered from a switched input.
The solenoid goes between the manifold/turbo outlet (you have a choice) and the top of the wastegate. We'll put up some more pictures shortly.
Posted: Mon Aug 01, 2005 9:41 am
by k20tuRbo
Hondata wrote:You really need to read the help file. There is a low and high setting, triggered from a switched input.
alright thanks
Solenoid Plumbing
Posted: Mon Aug 01, 2005 10:07 am
Here is how to connect the solenoid for a typical setup.
Posted: Mon Aug 01, 2005 11:47 am
by 02SilverSiHB
whats up with the foam filter?
Posted: Mon Aug 01, 2005 12:43 pm
by locash
To keep dirt and debris from clogging up the solenoid..
02SilverSiHB wrote:whats up with the foam filter?
Posted: Mon Aug 01, 2005 2:52 pm
by 02SilverSiHB
locash wrote:To keep dirt and debris from clogging up the solenoid..
ah!
Posted: Mon Aug 01, 2005 5:33 pm
by k20tuRbo
that picture helps alot, could you please give us instructions on the wiring?
Posted: Tue Aug 02, 2005 5:56 am
by 02SilverSiHB
k20tuRbo wrote:that picture helps alot, could you please give us instructions on the wiring?
I think he mentioned it's in the help file
Posted: Tue Aug 02, 2005 6:01 am
by k20tuRbo
02SilverSiHB wrote:k20tuRbo wrote:that picture helps alot, could you please give us instructions on the wiring?
Ok reading it now
Posted: Tue Aug 02, 2005 6:14 am
by 02SilverSiHB
open kmanager
click help then contents tab
Then go to Windows and double click to open contents under it
Double click on Parameters Window.
Then scan down to Boost control and select that, it will tell you everything and even show the same pic
