SiK LiL pLaYa
Posts: 22 Joined: Wed Apr 20, 2005 9:49 am
Post
by SiK LiL pLaYa » Sun Jul 31, 2005 10:34 am
02SilverSiHB wrote: SiK LiL pLaYa wrote: 02SilverSiHB wrote:
you're joking right? you're asking if the boost control works on NA?
THat is NOT what I'm asking. I was wondering if the fuel and ignition correction would work on NA as of right now. I know Hondata planned on including this in KPRO so am wondering if this is it or if its something else for NA cars. I guess I should have been more specific.
My BAAAAD.
lol! sorry man..I was like..uhhhhh, wtf?
All good, that was all my badd lol.
MAX POWER 204.3/MAX TORQUE 154.4
1/4 = 14.496
SiK LiL pLaYa
Post
by SiK LiL pLaYa » Sun Jul 31, 2005 1:42 pm
Nevermind my question. I see that this version has IGNITION and FUEL adjustability for NA cars. Thanks HONDATA.
1/4 = 14.496
Razathorn
Posts: 469 Joined: Tue Jun 14, 2005 12:17 am
Post
by Razathorn » Sun Jul 31, 2005 4:16 pm
I can't imagine that the per gear adjustments would be specific to running boost...
Dominic..
Posts: 29 Joined: Tue Mar 15, 2005 3:12 pm
Post
by Dominic.. » Sun Jul 31, 2005 11:04 pm
Kpro boost controller works in EUro Kpro?
and example valve selonoid from avcr could use with kpro?
k20tuRbo
Posts: 13 Joined: Mon Aug 01, 2005 8:12 am
Post
by k20tuRbo » Mon Aug 01, 2005 8:16 am
Can someone help with the install of the solenoid? I already ordered the parts.
also is there a hi low setting? I need to run 20psi at the track, I guess I just need 2 calibrations?
Posts: 10615 Joined: Thu Aug 15, 2002 12:13 pm
Post
by Hondata » Mon Aug 01, 2005 9:13 am
You really need to read the help file. There is a low and high setting, triggered from a switched input.
The solenoid goes between the manifold/turbo outlet (you have a choice) and the top of the wastegate. We'll put up some more pictures shortly.
k20tuRbo
Post
by k20tuRbo » Mon Aug 01, 2005 9:41 am
Hondata wrote: You really need to read the help file. There is a low and high setting, triggered from a switched input.
alright thanks
Post
by Hondata » Mon Aug 01, 2005 10:07 am
Here is how to connect the solenoid for a typical setup.
02SilverSiHB
Posts: 53 Joined: Thu Oct 03, 2002 8:39 pm
Post
by 02SilverSiHB » Mon Aug 01, 2005 11:47 am
whats up with the foam filter?
07 Si Sedan
locash
Posts: 280 Joined: Sat Mar 20, 2004 11:27 am
Post
by locash » Mon Aug 01, 2005 12:43 pm
To keep dirt and debris from clogging up the solenoid..
02SilverSiHB wrote: whats up with the foam filter?
02SilverSiHB
Post
by 02SilverSiHB » Mon Aug 01, 2005 2:52 pm
locash wrote: To keep dirt and debris from clogging up the solenoid..
ah!
07 Si Sedan
k20tuRbo
Post
by k20tuRbo » Mon Aug 01, 2005 5:33 pm
that picture helps alot, could you please give us instructions on the wiring?
02SilverSiHB
Post
by 02SilverSiHB » Tue Aug 02, 2005 5:56 am
k20tuRbo wrote: that picture helps alot, could you please give us instructions on the wiring?
I think he mentioned it's in the help file
07 Si Sedan
k20tuRbo
Post
by k20tuRbo » Tue Aug 02, 2005 6:01 am
02SilverSiHB wrote: k20tuRbo wrote: that picture helps alot, could you please give us instructions on the wiring?
Ok reading it now
02SilverSiHB
Post
by 02SilverSiHB » Tue Aug 02, 2005 6:14 am
open kmanager
click help then contents tab
Then go to Windows and double click to open contents under it
Double click on Parameters Window.
Then scan down to Boost control and select that, it will tell you everything and even show the same pic
07 Si Sedan
