FlashProManager 4.7.1
yaggs89
Re: FlashProManager 4.6.9
Post by yaggs89 »
Jester04 wrote: Sun May 17, 2026 5:20 am
EJHonda wrote: Sat May 16, 2026 9:34 pm
Netopsengineer wrote: Sat May 16, 2026 2:42 pm Your download link also isn't working for this version, and when I attempt to update Flashpro Manager from the software itself I'm on 4.6.6.0 on Windows 10, as soon as I click update it tries to launch `update.exe` like normal but I get:
Title: Unsupported 16-Bit Application
Message: The program or feature "\??\C:\Users\my_user\AppData\Local\Hondata\FlashPro\update.exe" cannot start or run due to incompatibility with 64-bit versions of Windows. Please contact the software vendor to ask if a 64-bit Windows compatible version is available.
My installation:
Edition Windows 10 Home
Version 22H2
Installed on ‎8/‎10/‎2025
OS Build 19045.6466
Same error messages here when attempting to download 4.6.9 from 4.6.6.0 Build 5835.
Edition Windows 10 Pro
Version 22H2
Installed on ‎9/‎26/‎2020
OS Build 19045.7291
I’m getting the same error message, went to download the software since the last version bugged out. Now can’t even download the software from the website.
I’m flashpromanagerless🤣
Same error here
R2Racing
Post by R2Racing »
Hi Spunkster,
my client (FP-RDX-160091) has the same issue. He hasn't been able to connect to the ECU since updating to 4.6.8 and then 4.6.9. He has already sent feedback through the app. Finally, he rolled back to 4.6.4, but it is asking to update to the newer version now.
Any advice on what we should do next?
Btw, FP has 4.6.8 bootloader 8 main 280 at the moment
dmoraroj
Post by dmoraroj »
Many of us still waiting for Hondata to reply on this treat. Actually we have observe that the current software version on the download page has been changed from the 4.6.9.0 to 4.6.6.0 since last friday (rolled back to a 2th April version....) but in the release notes says 4.7.0. Using the 'Check for upgrades' option in the FP Manager it says 'Up to date'..... But in my case this is not the most importat issue, I´m still waiting for FP device memory corrupted escalation response (in this same treat and mail) after download the 4.6.7.0 version last week.
Re: FlashProManager 4.7.1
Everything should be working now.
If you have an EBCAN purchased in the last two weeks which has a serial number on it then unplug the EBCAN when uploading. That will not be necessary after the next release which will update the EBCAN firmware.
typer86
Post by typer86 »
FlashPro License Corruption After Firmware Update
Hello Hondata Support,
The customer has already contacted you multiple times through the feedback system regarding this issue but has not received a resolution yet.
The FlashPro was functioning normally before the firmware update. After updating, the device now reports:
FlashPro Vendor: Unknown
Dealer FlashPro: Yes
Corrupted VIN data in the license section
Serial number displayed with a "?-" prefix
At the same time:
EEPROM Memory Test: OK
Flash Memory Test: OK
Firmware Checksum: OK
ECU communication is working correctly
This strongly suggests that the firmware update corrupted the internal license information while the hardware itself remains functional.
Could you please review this case and advise on a recovery procedure or RMA process?
Replacing the device would be difficult to justify when the issue appeared immediately after an official firmware update.
Additionally, can you clarify why new user registrations on the Hondata forum will not be activated?
=> Shady0286 = New User which reported the issue...
The car need further tune updates from me - I hope this issue will be fixed soon.
dmoraroj
Post by dmoraroj »
dmoraroj wrote: Sat May 16, 2026 6:02 pm
dmoraroj wrote: Fri May 15, 2026 2:48 pm Same result....
Somehow the device sometimes it seems is able to comunicate with Manager and in that I try to upload a file and shows the error in the image.... I think it is done.... what I see is the FW 279 caused a failure in a memory component inside the FP.
Can anyone from Hondata help me with my problem??? I received a couple of mails last week but nothing else!! I really want to know about the next steps....
dmoraroj wrote: Mon Jun 01, 2026 6:50 pm
What is the FlashPro serial number?
dmoraroj
Post by dmoraroj »
Spunkster wrote: Tue Jun 02, 2026 12:09 pm
Once again FP-2012SI-118115
Using now the Lates Software version4.7 , issue started with 4.6,when the FP resulted damaged.
So, you are not using 4.7.1?
dmoraroj
Post by dmoraroj »
Spunkster wrote: Tue Jun 02, 2026 3:38 pm So, you are not using 4.7.1?
Now waiting for RMA or next step from you.
